Question about Convair Portable Air Conditioner
My techno portable tac-10k is showing E2 on screen
E2 means damaged tube sensor on mine
Posted on Dec 31, 2014
Techno woshing macine e2 error code
please adjust the speed sensor, see the diagram , clean it , test for open or faulty, tight the connector very well. Run the software calibration for easy diagnost and fix it.
God bless youca6ac285-0d3b-4f8d-be08-b95be3c0bc40.gif075f693e-e499-4a20-a99a-23cd2bdd1cbd.gif
Jun 06, 2013 | Exercise & Fitness
Engine won't start and shows trouble code P1516 and reduced engine power light is on
Here is the definition of the code.
Possible causes - Faulty Throttle Actuator Control (TAC) module
- Throttle Actuator Control (TAC) module harness is open or shorted
- Throttle Actuator Control (TAC) module circuit poor electrical connection (loose or broken wires)
P1516 CHEVROLET Description The Throttle Actuator Control (TAC) module contains data which is essential for proper TAC operation. The TAC module continuously test the integrity of this data. When the TAC module is unable to write or read data to and from Random Access Memory (RAM), or the TAC module is unable to correctly read data from the flash memory or and internal TAC module processor fault is detected and the Detected Trouble Code (DTC) is set.
Read more: http://engine-codes.com/p1516_chevrolet.html#ixzz286Gl3cSo
Sep 28, 2012 | 2002 Chevrolet TrailBlazer
Check engine light is on and the car lost power. By checking with a portable meter, it showed "P2111 TAC system stuck open", what does it mean and how to fix the problem?
It means you probably have a bad TPS (throttle position sensor) or TAC, in the throttle body. Costs about $60. Is easy to change. While in there, make sure the throttle body is clean, because heavy coating of oil water, grit, etc. builds up and will inhibit function.
Jan 03, 2010 | 2004 Toyota Camry
My Trimline treadmill 1050.E2 is showing an 'E2' on its screen and not working any more.
Hello all,
I have the same issue - it Shows "E2" on the time Display...
I already checked the Speed sensor and inclination potentiometer and both are OK... Moreover, I found that EEPROM Memory (Microchip 93LC46) is broken (reads "00"). After replacing it, I Need a way to reset / recalibrate the treadmill. I found on some Forums that there shall be a key combination (Speed+ & Start / Stop or similar) but None works for me. Could you please (if available) post the User Manual page describing the calibration entry? Or, maybe, advice a way to calibrate the 1050? Even the EEPROM Content (I guess the it is an issue) will be really helpful. Thank you in advance,
Milos
Oct 06, 2009 | Nautilus Exercise & Fitness
Tungsten e2 is always looping on the stylus calibration screen
actually ur Digitizer is faulty u can replace it urself cost around 25 $ or so do u want to proceed let me know , unless u change the touch panel digitizer u will be stuck at align screen thing
let me know if i can help more
RATE ME WELL !
Jun 02, 2009 | Palm Tungsten E2 (Multilingual) Handheld
I want to view psp UMD on a larger screen i.e psp to laptop. how do i do it and do i need software or hardware to achieve it. I have tried to connect by USB but thick in techno. No Joy.
psp slim has a video output that allows you to connect to the tv
but to connect it to your laptop screen, i dont think you can
and if you meant just to view a umd on your laptop, like emulate it, i dont think you can
good luck!
Mar 18, 2009 | Sony PlayStation Portable (PSP) Console
Vizio model #L37
kNOBLE
VIZIO
L32
LCD
DEAD WITH AN AMBER LIGHT
Do Not Order A New Board For This Vizio Model. You Can Fix This Problem For Pennys. Problem: Will Not Power Up Amber Led Only. Hint: No Reset To Operate Micro (Brain Dead) I'Ve Seen (3) Various Fixs Below, One Uses A Diode, Other Uses A 10k Resistor, Try Either. All 3 Will Work, Diode Works Best For Me This Same Reset Ic Goes Bad On Other Visio Lcd & Plasma Tv'S. #1) You Remove Smd U26 On The Video Processing Board And (Add) Put A 10k Resistor Across Pins 2&3. U26 Is Near The The Tact Switch. #2) Remove U26 And Solder A 10k Tru 100k Resistor Across Pin 2&3. Start With A 10 K First. #3) Remove Reset Ic Near Tac Switch Replace With 1n4148 Diode (Nte519). Vizio Tech Support: (Valid - I Tried It) 1-888-849-4623 Opt 4 Technical Support: 888-849-4623 Try Extension 1669 (David). Hugo Carrera Parts Department 877-668-8462 Ext 1814 Vizio Inc. 320a Kalmus Drive Costa Mesa, Ca 92626 E-Mail:Hugo.Carrera@Vinc.Com
Mar 16, 2008 | Vizio L37 Television
Convair  Portable Air Conditioner Logo
101 people viewed this question
Top Convair Heating & Cooling Experts
Donni Steen
richie46
ray gallant
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
