Question about John Deere Garden
LX255 leaks oil from front of engine & smokes
Started after oil change
j_del
  • 1586 Answers
SOURCE: audi engine oil leak?
Sounds like a leaking valve cover gasket. The parts are around $50 to do both cylinder heads from www.ecstuning.com. It's not a major issue, but it may be a sore point to a potential buyer.
Posted on Oct 01, 2008
  • 36 Answers
SOURCE: Have a 96 ford thunderbird
Check the color of the oil if it looks like a chocolate shake you have a blown head gasket
Posted on Jan 04, 2009
  • 130 Answers
SOURCE: Craftsman mower with 26hp kohler smokes while cutting.
it sound like you put to much oil in it.if not check vent valve
Posted on Jul 18, 2009
  • 138 Answers
SOURCE: Riding mower engine loud and smoking.
take it to a reputable shop and have them check it over - courage engines had a problem when they first came out - the bolts in the cover plate were not torqued properly and when they come loose, the torque of the engine turning will crack the block - this should be a warranty condition if the block is cracked - just make sure the shop is a kohler warranty station
Posted on Aug 28, 2009
SOURCE: newly overhauled toyota corolla 2e engine emits black smoke
I have toyota corona 3s engine it smokes black and fuel consuption is high we have changed the engine oil and cylinderhead gassecate but still black smoke is comming what should i do
Posted on Mar 29, 2010
Dodge ram engine smokes when stated and skips
What color smoke? Black is emissions related, blue/black your burning oil and white your burning anti-freeze. With the "skip" your REF to, you probably have a bad spark plug, wire, or bad cylinder and burning some oil or coolant. CK plugs , wires & do a compression test. Pressure test Radiator for head gasket leak.
Jul 04, 2014 | 2004 Dodge Ram 1500
2003 lincoln aviator/how do you know if there's motor damage
Your car shouldn't have just suddenly started burning oil. Its possible it's leaking in the engine compartment and the leak is dripping onto the hot exhaust manifold and the. The smoke is blowing out the back as you drive. I would think it's unlikely that the engine has been damaged since the check-engine light should have come on if the oil level was low enough to cause damage.
If hii find that bluish smoke is coming from the exhaust pipes, then the next thing to check is whether it smokes on acceleration or deceleration. If the latter, it may be just a valve issue. If it smokes a lot on startup, then it may be rings.
Aug 09, 2017 | 2003 Lincoln Aviator
Chevy Prizm or Toyota Corolla 2000 valve cover gasket problem? Right after oil change, engine check light came on & car started smoking & losing oil. I took out all 4 spark plugs: they were in very...
The valve cover gasket isn't hard to change. Oil on the plugs indicates a more serious problem. Smoke from the exhaust would be from rings, rich mixture, worn valve guides. It may be that the engine is overfull (that would show on the stick). Oil loss from a leaking gasket would smoke under the hood and leave oil on the engine and the ground.
Mar 25, 2011 | 2000 Chevrolet Prizm
I change oil in my nissan titan v8 and after the engine started smokeing what do we do to stop the smoke.
if the smoke is coming from the engine bay, check for spilt oil or an oil leak, especially on the exhaust. clean/fix this and the smoke should stop.
if it is coming from the exhaust, check you have used the correct grade of oil (too thin oil may bypass oil seals slightly) and you have not overfilled the engine and this can cause internal pressure, causing oil to bypass the seals, or even blow oil seals completely. overfilling will also damage the catalytic converter.
Feb 23, 2011 | 2004 Nissan Titan
I have a 2001 Saturn L. Oil is leaking, it is not the head gasket. Tore engine apart and replaced gaskets. Stopped leaking for about 6-7 months and it started to leak again. Did oil change last week...
If you have no visible signs of oil leaking out of the engine then the oil is being burnt. By visible leaking I mean a small puddle of oil under the car after having been left overnight. This can be cured by replacing shaft seals and gaskets. Burning oil is visible as smoke under deceleration (no throttle) and under full power(flooring it). This is due to worn/old valve stem seals(smoke under deceleration) and worn oil rings(smoke under acceleration) This can only be cured by a major engine overhaul or engine replacement. Bear in mind that losing a pint of oil in 1000 miles is acceptable.
Sep 25, 2010 | 2001 Saturn L-Series
My 04 VW Jetta blew thick white smoke from tailpipe after freeway drive. No indicator lights came on, all oil leaked out (after smoke started)... is this engine or could it be just the turbos? Right...
A new turbo charger is about $340, but you can buy the bearings and seals and rebuilt if yourself for about $100
http://turbosandparts.com/
It is not hard, and it does not take long to do.
I normally do not bother with synthetic, but with a turbo charger, it might be worth it. What really seems to ruin turbo chargers the most is not letting them cool off before parking.
Once you turn off the engine, there is no longer any cooling, so the build up heat will burn up the oil and seals.
Run the engine for at least 5 minutes below turbo levels, before shutting down the engine.
Sep 06, 2010 | 2004 Volkswagen Jetta
I just bought a 96 dodge caravan 2 days ago ive drove 150 miles today and when i went to shut it off it had smoke i raised the hood its coming almost directly from the front of the van i went to leave...
How low was the oil? It could be something as simple as some oil is leaking out of the valve covers and once it hits the exhaust manifold then it starts smoking. Usually smoke coming from the engine compartment is a result of that. Look and see if it leaks any oil while you have it parked in pavement for a while in case it has something to do with the oil change.
Good Luck
Oct 08, 2009 | 1996 Dodge Caravan
Smoke and oil coming out of the front exhaust of
chech engine oil level ,if oil level its up carburetor flout neddl valve leak and the fuel run into engine
Aug 22, 2009 | Garden
Garden Logo
82 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
