Question about Cobra Radio Communications
Omron sysmac c20 program examples - Cobra Radio Communications
How can I get a manual for omron blood pressure monitor HEM-7200
Here is the official site for Omron manuals:
http://www.omron-healthcare.com/eu/en/support/manual
The manual for that model is one of the skimpiest manuals I've ever seen!!
Dec 29, 2014 | Omron Health & Beauty
Manual omron sytem9400
This is a PC Desktop?
Mar 06, 2013 | Computers & Internet
How to connect an omron h3y timer into a circuit
I see your comment to ignore:
To protect timer, read following:
1) Max load on this timer is 5 amp at 240volts
http://waterheatertimer.org/pdf/Omron-H3YN0302.pdf
2) If load exceeds 5 amps, then use timer to control contactor.
Here is crude drawing showing basic wiring for pin timer controlling heavy amp load.
http://waterheatertimer.org/images/10-pin-wiring2-1000.jpg
3) If amp rating on incoming wires exceeds 5 amp, for example is circuit breaker feeding circuit is 20-30 amps etc, then protect wires to timer using busman in-line fuseholder with fast-acting 5 amp cartridge fuse.
Dec 03, 2012 | Omron Healthcare Omron H3y-4 5 Second...
How do I program the H5CX ASN timer to turn on 5 mins and off 25 mins in an endless cycle. I don't understand the term Output Mode so from that point the instructions become meaningless.
Omron:
https://www.ia.omron.com/support/
http://waterheatertimer.org/pdf/h5cx_sell-sheet-wiring.pdf
I believe you have 230Volt 50 Hz electric power.
Omron is rated 50-60 hz
US timers are rated 60 Hz.
Maximum load on Omron timer is 5amp at 230 volt
Timer should be connected to 2-pole contactor (relay) instead of directly connected to pump.
http://waterheatertimer.org/images/contactor-drawing.gif
Does Amazon sell percentage cycle timer in your country?
A cycle timer makes one full revolution each hour, or 4-hours, or 12 hours. Then percentage is set for 8% for 1 hour cycle.
Contact Intermatic and ask if they have 50 cycle percentage cycle timer, or ordinary cycle timer in 50 Hz.
Nov 22, 2012 | Omron H5CX A AC100-240 Multifunction...
Omron gosmart hip pedometer hj-151 manual
Monitoring your personal exercise will surely result in a satisfactory feeling of well-being. Omron Pedometer gives exact readings of how many miles/kilometers you have walked. Here's your manual for Omron HJ-151
http://www.omronhealthcare.com/wp-content/uploads/hj-151-instruction-manual.pdf
Aug 23, 2012 | Omron Sport & Outdoor - Others
Omron bp710
I use Omron blood pressure monitors and I can say that they are up to the mark. Their readings are very accurate and have not caused any problems so far.
Aug 03, 2012 | Omron Automatic Blood Pressure Monitor w/...
I need a wiring diagram for an Omron H5CX-A timer
Wiring will appear on side of timer.
Test the timer with multimeter to see which terminals are connected. When timer has no power, then Com and NC terminals will have continuity.
H5CX-A Timer has 11 screw terminal connections and timer is rated 100V to 250Volt AC 50-60Hz.
Input is power IN > this is the 100V to 250Volts coming from breaker box or transformer. For example input terminals might be labeled A and B.
This will give power to timer, but remainder of screw terminals have no power.
To put power to relay terminals, jumper the power from Input terminal A to COM terminal.
For example Com terminals might be 7 and 9.
So jumper Hot wire from Terminal A to terminal 7.
This action will put hot on Com terminal 7, but also give power to the NC terminal.
For example the NC terminals might be 1 and 3.
So when timer is OFF, the NC terminal has power.
Then when timer turns ON, the NC terminal no longer has power, but the NO terminals are Hot.
NO terminals might be 4 and 6, and these terminals turn on-and-off when timer turns on--and-off
Open following link to help with Omron 11-pin wiring:
http://waterheatertimer.org/How-to-wire-pin-timers.html
Jun 14, 2012 | Omron Hardware & Accessories
OMRON RS4602 EPOS - CG file full, cannot clear screen and cant find any info anywhere about how to, any ideas?
Some Omron cash register manuals here too:
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
omron RS-3010E Programming
omron RS-3010 User(R) Service(R) Programming(R)
omron RS-3410 User(R) Programming(R)
omron RS-3460 Programming(R)
omron RS-4601 Programming(R)
omron RS18 Programming(R)
omron RS25 Managers guide(R) Programming(R)
Jan 02, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
Radio Communications Logo
27 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
