HYPERCOM T7C WILL NOT PRINT
I REPLACED RIBBON AND PAPER..WILL NOT FEED PROPERLY OR PRINT.
2 Suggested Answers
  • 14 Answers
SOURCE: How do we enable our Hypercom T7p printer- we chan...
To Fix it.
Blue Function + 71 Enter
Printer is Disabled
Enabled? Yes/No
Hit Enter for Yes
http://www.gorillapaper.com/hypercom-t7p-t-thermal-terminal.html
Posted on Jun 09, 2010
I just replaced the typewriter ribbon my Brother ML-100 typewriter; however, it does not advance properly so typing does not appear on paper. What is the problem?
Take the ribbon off, see if it advances with the hand feed wheel if not you have a bad ribbon. Type without the ribbon and be sure the ribbon driver is turning. There may be a switch or setting for use of an overstrike ribbon,
DickyO
Aug 28, 2013 | Brother ML-100 Typewriter
Paper
A T7+ is a drop and load terminal. Simply open the lid, drop the paper roll in, feed about an inch of the paper out from the bottom of the roll, then close the lid.
Feb 20, 2012 | VeriFone (M19755014US1) Magnetic Card...
Although I replaced the ink cartridge, the fax text is fainted.
You want to make sure the print head is not dirty or dusty. Remove the ribbon and clean the metal print head you see under the ribbon.
If this does not work then the print head is simply not warming up properly and you need to service it.
Thanks,
Pat
May 11, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
I have replaced the toner cartridge but now it keeps saying "no print cartridge", I have taken it out and back in several times, turned it on and off several times but still says no print cartridge...
I just had a customer with this problem. Turns out they had a paper jam. 1 piece of paper from the paper tray was about 1/3 of the way up the paper path (had some ink on it). But it was stuck. They should have had a paper jam error but instead had a "no cartridge installed" error. Go figure.
Jan 13, 2010 | HP Laserjet M1319F Laser Multifunction...
I'm having trouble with the Javelin J330i printer. When trying to print cards it doesn't pull them through correctly and then gives an error that the ribbon is broken. I have tried resetting the printer,...
check the feed tires ,the ones that feed the paper/cards into the printer. they maybe slick with paper dust. I recommend taking a cotton dish cloth or rag with some 409 cleaner on it the the feed tires clean all the paper dust off the tires let dry then try to feed card again. sound like the sensor is covered with paper dust, and is giving a false error.
Jul 09, 2009 | Javelin Systems Inc Javelin Viper PC...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printhead light comes on
if you are using software that using printer please the s600 printer driver to direct thermal mode to solve the problem.
Aug 18, 2008 | Zebra Stripe S600 Thermal Label Printer
Printer is not aligning paper properly.
Please try the following to resolved that issue:
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
Jun 10, 2008 | Epson DFX-9000 Matrix Printer
13 people viewed this question
jasbo
jasbo
