Question about Garden
On a John Deere 430, what could be overheating to cause pto to fail to start after tractor is warmed up
PTO always starts when cold, but when tractor is warmed up after mowing, and the PTO is shut off, it will not restart.
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 69 Answers
SOURCE: THE PTO LEVER ON A 210 JOHN DEERE GARDEN TRACTOR
I believe there is an adjustment for this. Check
www.weekendfreedommachines.com for specific info. Look in the Restoration and Repair Forum.
Posted on May 06, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
  • 47 Answers
SOURCE: Engine Dies and will not start when PTO is off, brake depressed.
Let me guess, as soon as it sets still for a few hours, it fires straight up again, like there was no problem? :D
If you have one with the Kohler 12.5 Command Pro Engine:
These have a known issue with the ignition pickup/coil assembly. If you feel confident in your skills, removing the upper engine shroud will reveal the coil pack. Loosen the bolts and adjust it's width from the flywheel using a business card as a feeler gauge to set the gap. The card should just *slightly* bind between pickup and flywheel. If it STILL stalls and stumbles and eventually quits AFTER it is hot as you describe, likely the coil pack is tired and worn. Heat will make them short out internally as internal windings expand from heat. Replacement is the only cure. About $40 from Kohler, about $60 from John Deere.
Posted on May 09, 2010
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
John Deere la125 somebody rigged PTO so it's engage always and causing mower not to start or starts hard.what am I looking for to correct this?
find the wires to the PTO and trace then back to the switch
connect correctly(Probably done because of a faulty switch in the first place )
May 26, 2016 | John Deere Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Eletric PTO is not working
The PTO draws a pretty good current, so a weak or loose contact in the switch, or in the connections on the back of the switch, could cause this overheating. But it could also happen if the PTO clutch itself or the wiring to it has a short. If the mower's still under warranty, get the dealer to diagnose and fix it. If not, then I'd measure the resistance of the PTO clutch - should be about 2 ohms - and make sure the wiring to it isn't shorted. If all that is OK, then just replace the PTO switch and any melted connectors and wiring. Good luck!
Jul 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD 420 PTO works fine when cold/newly started. after warming up, if i turn off PTO, the PTO will not re-engage. is this a switch problem? other problem? if a switch problem, it looks like it's somewhat...
I used a neighbors 420 while mowing and there were times that I tried to restart the blades after turning them off for a bit. I found, I think, that you had to have the brake depressed to make them turn back on.
Oct 17, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Engine starts and runs Great. When I engage the Pto leaver on my John Deere L100 the mower fails.
at the point of lowering the pto it's trying tosuck more air to mix with the gas .you might just need to change the air filter.
Jun 07, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
