Question about Konica Minolta Bizhub C25 C35 C35p Color Printer Transfer Belt Tf-p05 Tfp05
Where is the transfer belt located on a Konica Minolta C25
  • Konica Minolta Master
  • 6,161 Answers
Above the 4 drum units have to remove the 4 toners the 4 image units and the transfer belts is removed from the right side after removing a section of the duplexer on the right side door.
Posted on Dec 29, 2015
Kevin Hayes
  • 167 Answers
SOURCE: Konica Minolta Bizhub C450
You need to place service call for the transfer belt.
As for Sally's question, select the "seperate Scan" button to combine multiple documents as one file. This will work with or without the auto document feeder.
Posted on Jun 12, 2008
  • 214 Answers
SOURCE: Konica minolta magicolour 2530dl
open side door and there is a transfer roller / one big black roller on the cover/ try reinstall it, maybe its not installed correctly
Posted on Jul 02, 2008
  • 24 Answers
SOURCE: How do I remove a Konica Minolta Bizhub 352 transfer belt?
Two screws front and rear need to be removed before the belt will come out, it is light sensitive so keep it in the dark.
Posted on Jun 25, 2009
  • 158 Answers
SOURCE: I have a Konica Minolta Bizhub C350 which is now
I would advise having a copier technician replace those items it is not that hard to do but if you dont get the roller seated in the holder properly it can destroy the transfer belt and that could get expensive
Posted on Dec 02, 2009
  • 214 Answers
SOURCE: change the transfer unit on a konica Minolta
open right door, remove 2 lock screws and pull out the tbu
Posted on Dec 16, 2009
How to clean belt sensar in Konica Minolta c550
Remove the transfer belt. Then you will see two sensors located just below the end of the transfer belt closes to you ON the machine not the belt. there is cover you can gently slide it back and with a dry wag or gentle bush clean them you have to place you finger on the metal slide to slide to uncover them. pull slide to the front of the machine
Jun 05, 2017 | Konica Minolta Office Equipment & Supplies
Hi I have a Konica Minolta C-550 I appear P. -21 code After I changed the UNIT appeared to me Code P. -5 What should I do
I am going to assume you replaced the Transfer belt and transfer roller. Since you did not state that in your input. You did replace both at the same time. Cleared the counter for the transfer roller in the service mode?. Anyway the code P-5 and P-21 have to do with the registration sensor located below the transfer belt. On the right side of the machine. Where the edge of the belt is and exposed below the belt and behind the large plastic part below the belt there are two sensors one to the front the other to the rear of the belt, again below the belt assembly. It will require you the expose the sensors clean them. Worse case have them replaced, or the Main board!!!!. Recommend you have a Konica Minolta tech come out and do this procedure. P-5 is the front sensor failure
Apr 05, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Error p 5 konica milnolta bizhub c450
Remove the transfer belt. Then right below the fusing unit right where the edge of the transfer belt is located when normal installed right below where the edge of the belt would be. Are two sensors they are cover with the belt out and door open so you will have to GENTLE open them with your fingers and GENTLE clean them DO NOT USE AVACUUM CLEANER THE STATIC ELECTRICTY from the vacuum cleaner can destroy the sensors.
Mar 25, 2014 | Konica Minolta bizhub Office Equipment &...
Error p5 in konica minolta c450
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed..
Mar 01, 2014 | Konica Minolta Office Equipment & Supplies
IDC sensors are located under the transfer belt on the right sid eof the machine. Belt must be removed to clean sensors. Once belt is removed sensors are located on a black plastic frame and have slideable covers that can be moved by hand to clean sensors. There are 2 sensors one machine front and one machine rear.
Mar 01, 2014 | Konica Minolta bizhub Office Equipment &...
The machine status of my konica minolta is p21, what does this mean?
P 21 Color shift test pattern failure.Relevant electrical parts is the image transfer belt unit.
Wipe clean the surface of the transfer belt with a soft cloth if it is dirty.Change the image transfer belt unit if the transfer belt is damaged.Clean the 2 sensors located upper side of unit.
Apr 18, 2013 | Konica Minolta Office Equipment & Supplies
My Minolta Bizhub c250 has lines of blue and red going though the images. It also seems to be printing Dark. Is this likely a drum issue or something to do with the fuser or transfer belt?
Open the front cover pull out the Cyan,Magenta,Yellow,Black image unit,clea used a vacum cleaner the copier inside.Open the right cover and remove 2 srews,remove the transfer belt unit and clean the transfer belt cleaning blade and the transfer roller unit located on the right cover.
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
WHERE IS THE TRANSFER UNIT LOCATED ON KONICA
Unit is in the right side cover. New one should have instructions with it, but I think you unlock a handle and swap, then lock handle again.
Apr 06, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub C25 C35 C35p Color Printer Transfer Belt Tf-p05 Tfp05 Logo
44 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
