Question about Kurio Home
Keyboard wont come up to put in wifi code. - Kurio Home
The wifi switch wont move to on
Hello Kim
try this
1) Press firm and move to on position. check
2) bad on off bottom (need to change)
3) try to see if you have on keyboard a wifi option to on the signal * on some models only of course.
4) spray the bottom to clean dirt, or clean the botton with alcohol 70% with QTIP
Carl
Sep 24, 2016 | Acer Aspire 5552 5552g 5553 5553g 5560...
My hp compaq nx 8220 request for smart card, how do i clear it
When you restart, try pushing down (not to hard) with your fingers under the 2 alt buttons (not the keyboard) until the windows logo shows.
If it's like the nc6220 then it's not a bug, it's a design fault.
you need to be able to do bga reflow to fix this, and you need to ditch the wifi card.
if you remove the wifi card, there is a big chip under it with silver foil on top of it, that's HP's sorry attempt at a heat sink because they had no space between the chip & wifi card. You need to remove the foil, reflow the chip - it wont need a reball, then glue a heat sink on the chip and put the cover back without the wifi.
if you just reflow it without dumping the wifi-card for a heat sink, it will just fail again
Apr 11, 2016 | HP Computers & Internet
My fosmon keyboard case worked with my old router which packed up working but it wo'nt wok with my new router ??
I can't believe the keyboard ever worked with a router. The keyboard worked with blue tooth to your tablet, or with a WIFi or blue tooth dongle in the computer..
Jan 22, 2015 | Computers & Internet
I cannot connect to the internet
Is this the wifi password? If so it is case sensitive...... Make sure you are entering it correctly!
Dec 25, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
My wifi on my phone wont turn on
did you double check that you don't have it in airplane mode?
Nov 10, 2013 | HTC Explorer A310e 3g Wifi Android...
I had to reboot my lap top and now my wifi on it wont work
just click the restart.by clicking start menu/shut down/restart.
to on your WiFi.press the fn key and the WiFi key located on the f keys at the top of the keyboard.some laptop have a lock on the side to open the WiFi.just check your laptop on both side.you don't need to press fn/WiFi key it is having the WiFi lock on the side.
Sep 23, 2011 | Toshiba Computers & Internet
My grandson has a DISXL and is trying to set it up for the internet. I am getting error code:051110-1. It is also asking for a security key. I need help.
do you have wifi? If you don't have wifi it wont connect. Plus if you do have wifi you prob. put a sec code in to block outsiders. so you need that same code to access your wifi
Dec 30, 2010 | Nintendo Toys
My wifi is
Use the "Fn" key in combination with one of the F Function keys(example - F1 F2-F3 etc.) above the set of numeric keys. It will be a dual symbol key, meaning it will have wireless icon printed on it or the word "WiFi" in addition to the F number. It is usually one of the first 3 or 4 F keys. Remember, the "Fn" key must be pushed at the same time. It is a key combination like using <shift> and a regular alpha key to put a letter in CAPS.
Hope this helps Fixa! I am online if you need further help.
Apr 08, 2010 | Sony VAIO VGP-WKB1 Keyboard
Install wifi card
Undo the four screws near the screen on the underside, pull the panel above the keyboard out. Remove the four screws holding the keyboard down, there should be a slot for the wifi card along with two leads which you plug into the card (do this first so as not to put pressure on the slot)
Jul 06, 2008 | Computers & Internet
Home Logo
63 people viewed this question
Top Kurio Home Experts
thinksewfast
 Mikey
Mikey
Mister Danger
Are you a Kurio Home Expert? Answer questions, earn points and help others
