Question about Vehicle Parts & Accessories
A/C works on and off not all the time what is wrong?
It might work in the moring but not inthe afternoon what is it a bad conection ?
    New Friend:
    Problem Solver:
  • 20 Answers
Could be a loose connection, but I would guess it is low on refrigerant. Works under cooler conditions (light load) but not when it's hot. Could also be a poor or low radiator. I would first make sure the AC clutch engages when AC is selected (watch clutch at belt when engine is running and helper turns on AC). If the clutch always engages and you don't get cool air, it is NOT a loose connection, and I would make sure the radiator is good. You might then try a fill kit from an auto parts store but you need to know the low pressure side of your system. If you don't know this, I recommend taking it to a mechanic. Hope you have one you can trust, I went for years with no AC because one mechanic told me I needed a new pump. 5 years later, when I decided I could afford it, another mechanic just refilled the system and it worked fine for years after that.
Posted on Sep 08, 2014
My front fog lights, dash dails light and back lights dont work, i tested all the fusses with a test light, nothing seems to be wrong, there all still good, nothin is burnt. I do not knw whr the second...
try the switch its self it could be bad i had one that was , i had to slap it and it came on lol but im not recomending hitting it even if it worked for me that one time but i would say to take it out and test it and the wires
Feb 16, 2013 | Cars & Trucks
I have had my Transfer Case Encoder Motor in my 2005 1500 Z71 replaced 2 times inthe last month, the last one replaced was less than 5 days ago. The last 2 mornings when I have started the truck the 4wd...
I would say the transfer case is hanging up and destroying the motor., and no there are no recalls, maybe technical service letters but these are not recalls.
Sep 26, 2012 | 2005 Chevrolet Silverado 1500 2WD
My kicker l7 shows nothing wrong with it but wont work all of a sudden. whats wrong with it/
Faulty speaker wire. Dry joint in amp. Take speaker out & play with + & - wires on actual speaker to see if bad conection before cone
Sep 15, 2012 | Kicker 02S10L74 Car Subwoofer
My mitsubishi will not start in the morning but will start int he afternoon
Don't use my answer as the right one but it could have something to do with a worn out battery or the fact that everything is warmer in the afternoon which allows easier cranking of the engine since it requires less energy/force whatever to turn it over and ignite to start the engine. (Since fuel and air is warmer which ignites easier under compression stroke. Not 100% sure but hope this gets you further mate. :)
May 29, 2012 | 1998 Mitsubishi Diamante
I have the radio code but every time I put it in it does not work. Am O doing something wrong?
you may be using the wrong code.
The radio SERIAL NUMBER is required for a code First remove theradio from the dashboard. Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped inthe metal casing. This information canthen be used to see if a code can be calculated
May 15, 2011 | Car Audio & Video
Wifi button won't work When I depress the wifi button it stays orange instead of turning blue.
Look by the clock.. on the start bar for a icon to conect
open it and makesure its on,, and then conect to you WIFI, try reseting your wifi router, try reseting your internet box
If you already know how to do all that with no luck,
check the drivers for the wifi card
Its ether not conected to a network, lost driver, wrong network setings or bad wifi card.
May 16, 2010 | HP Compaq nc6220 Notebook
Planar 80mm T*,wrong 1,2,4 speeds
I have been repairing Hasselblads since 1991. I can tell you that removing the shutter for repairs is a time consuming task that requires patience and tolerance. All of the screws are flat blade, nine in particular that are hard to reach without the proper set of drivers.
The shutter has a gear train that needs to be cleaned and lubricated to fix the lower speed problem. It is common since they are rarely used in commercial work
Sep 23, 2009 | Cameras
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
