Question about Canon PIXMA MP160 All-In-One InkJet Printer
Pixma error message solution
No one has mentioned this solution: Use the scanner. Scan a document to a piece of manila folder cut to about letter size or smaller. The printer was able to feed this thick paper without a problem. Next, I performed the roller cleaning option. After that, the printer worked fine for photo paper. The Pixma MP160 has worked fine for me over the last four years. I print photos with it and the results have been extraordinary.
    Top Expert:
  • Canon Master
  • 78,267 Answers
We are here to post solutions.
Posted on Jul 13, 2017
4 Suggested Answers
yalmer
  • 552 Answers
SOURCE: Scale from legal to letter
Legal size is 11x17 inches and you cannot get a legal length document when selected for landscape.
Landscape means that it is 11 inches high and 17 inches wide.
You need to set it to letter and select 11x17 inches.
Posted on Jun 23, 2008
  • 193 Answers
SOURCE: canon pixma won't print documents
hardware problem...contact canon website
Posted on Dec 30, 2008
pineworks
  • 4041 Answers
SOURCE: Have same printer Cannon Pixma MP160 all in one.
Hello there
You may still have a little bit there some where This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
When i try to scan a document i get a message telling me to place the doc in a certain way.
I'm not familiar with this type op multifunctional, but from what I know is that the software might suspect a certain size of document. When the document you need to scan is smaller or somehow in another size, it is not recognizing the document. See if there is an option in the software for custom document sizes.
Oct 19, 2014 | Canon PIXMA MX330 Multifunction InkJet...
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From
your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Using HP4180 on windows 7. When I scan it saves file on letter size format. How can I crop or change scan size befor saving?
you might need to change the settings on the document/s letters before scanning depending on which program you are using to make this document ?
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
if you need more help with this post a reply
hope this helps
Aug 16, 2011 | Computers & Internet
I just installed a (new out of the box) HP LaserJet 3380 All-In-One printer/fax/scanner. I have NOT set up the fax function (no telephone line available). The unit is connected to my computer with a USB...
WHen you open the scan application and get to the point just before you scan... open at the top menu "File" and request to "Save As" and give it the "Name.BMP" see if that helps..
You named the folder but you did not mention naming the file you want to save????
Aug 04, 2009 | Office Equipment & Supplies
Won't scan legal documents properly
before the scan you will have preview. when you get preview adjust i mean make large the document size
May 29, 2009 | Samsung CLX 3160fn All-In-One Printer
Error message code 2,140,0
I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Mar 16, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Using PaperPort 11 to scan
If you will go through the Advanced Setup wizzard and it completes you will have access to the "Display Scanner dialog"
Jul 18, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Feb 06, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
