Question about YIBOO Toys
How do I tell if my yiboo helicopter is charging?
The green light on the charger is steady, and not blinking.
SOURCE: The instructions say that the
It's a typo in the instructions. The helicopter must be turned off to be chaged
Posted on Jan 04, 2009
SOURCE: Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Posted on Jun 23, 2009
  • 28 Answers
SOURCE: Battery Charger displays green blinking light
This is likely a code from the computer system on the CMM1200 that the batteries no longer hold a charge. If you have a voltmeter, a "quick test" is to put the batteries on the charger for at least 8 hours and then test the DC voltage of the batteries. Test each battery separately by taking the cables off and testing the battery at the positive and negative lead. If they read less than 11.5 volts, you need a new battery set. You can get replacements from www.batteryinternational.com/universal-battery-ub12180-batteries-by-brand-universal-battery-nb.html. The model you have requires two of these batteries. Hope this helps.
SOURCE: Yiboo AH-64 3D RC Mini Apache Helicopter
There is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter. I had the same problem with the top rotors, and had to go in and re-insert the rotor shaft and tighten the set screw. I applied locktite to the threads to prevent it from backing out. It works now, but one problem I notice is that there must have been a spacer bushing between the two gear wheels. Without the bushing, it will still fly, but I can feel some play in the upper shaft and wonder if over time that the counter spinning gear wheels will start to wear against eachother.
Posted on Feb 10, 2010
SOURCE: right out of the box
did you turn the radio on first. It must be powered up with the throttle stick at minimum. Turn power on and then move stick to maximum and back to minimum. The remote lite should stop flashing and then power on helicopter.
Posted on Dec 28, 2010
I have a skyforce gravity r/c helicopeter trying to fix for my son.When it is plugged in the charger, it just blinks green light. Have it over night, and it is still just blinking green. Have lost remote....
It means that the charged battery is full. Some chargers have a steady glow, others have a flashing light to show that the battery is charged. When you run the helicopter, is the battery fully charged, does the helicopter blades spin flat out? If so, the battery is charged and the flashing light indicates the battery is charged. If the battery isn't charged or the blades don't spin enough to lift the helicopter, or fly for some time, then the battery isn't charged and the charger may be faulty. Take it to a hobby shop to see where the problem lies, the charger and its blinking light, or the battery.
Dec 28, 2014 | Toys
Yiboo uj422 helicopter won't charge
Sounds like your batteries have gone bad.
Nov 10, 2014 | Toys
Bosch charger not charging
Its sounds simple but always worth a try, clean all the contacts on the charger, one will read the condition of the battery, If this is dirty, it may not be giving a strong enough signal to the charger and as such it will interpret the battery as faulty.
Dec 06, 2013 | Drills
NIKON MH26 BATTERY CHARGER BLINKING GREEN LIGHTS
A blinking green light means the charger is charging the battery. A steady green light (same LED) means that charging is complete. If the light never stops blinking and we assume that your charger is working correctly, you may have a defective battery. Rechargeable batteries do not last forever. After a few years, there ability to take and hold a charge declines. It may be time to buy a new battery.
Apr 10, 2013 | Nikon D Cameras
Helicopter charging red light not blinking
The charger may not be plugged in all the way in either the helicopter or the wall.
Aug 22, 2012 | Toys
Volitation 9053 flashing green light when charging brand new out the box
I have the same problem. I watched the video on helix.com and it shows it off while charging, but mine blinks for like 3 hours then turns solid green so I guess it is done. Anyone care to comment???
Nov 17, 2011 | xheli 9053 Outdoor Volitation Metal...
Me and my dad have 2 yiboo Uj4708 helicopters. We need to know how to change the frequency on them so we can fly them simotaniously. We can change the frequncy on the remotes, but don't know how on the...
Turn both helicopters and remotes off. Then switch the remote to another channel, either a,b, or c, turn on HELICOPTER FIRST, turn on REMOTE second. Move throttle up and down, helicopter should start responding.
Dec 26, 2010 | Toys
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
Toys Logo
50 people viewed this question
Top YIBOO Toys Experts
ray gallant
Are you a YIBOO Toy Expert? Answer questions, earn points and help others
