Question about Garden
How much oil do i need to change the oil in an ex40?
2 Suggested Answers
  • 172 Answers
SOURCE: ex40-2 slow on one track motor,may be loosing
I am assuming this is a Hitachi EX40-2 mini-excavator. Two tests that need to be run. First is the propel motor pressure equal to both propels? Secondly, but possibly more important is to check the slow propel motor for excessive case drain. This would indicate the propel motor is worn out. Find in your hitachi service manual the accepted amount of case drain for that model, disconnect the case drain line from the propel motor and cap the line. Install another hose to the case drain port with the other end in a 5 gallon bucket. Start machine and run propel for 30 seconds. Shut off and check amount of oil in bucket as compared to acceptable amount of leakage from machine spec book. All this does is measure the amount of leakage past the propel motor slippers, which gives an indication of excessive wear tolerances. Replace propel motor if needed.
Posted on Jan 05, 2010
How many hours should it take to service a hitachi ex40 excavator.
depending on the service schedule , that they are working from and which you have I would think 4 hours would be appropriate and up to 8 hours max
Most service schedule books have a service time in the service list
write a complaint to Hitachi management about the service center and consider lost time income from the service dealer
Apr 14, 2018 | Cars & Trucks
Robin Subaru EX40 engine will only run at idle. Increasing the throttle causes it to stall.
Try blowing your gas line out.. sounds like your getting gas but not enough
Oct 13, 2014 | Motorcycles
Why is my oil life percent is 9 and can I drive still or I have to change engine oil soon for the mercury mountaineer 2006
Regular maintenance is needed for oil changes. If your oil level is dropping you need to keep it up to operating level but you do need to find out why it is burning or losing oil. If your oil is black then it needs to be changed regardless of the miles on it.
Apr 20, 2014 | 2006 Mercury Mountaineer
Ex40-2 slow on one track motor,may be loosing digging power when working hard,have change hydraulic filter and track motors oil
Jan 04, 2010 | Garden
How often do it need an tune up,oil change engine coolant and brakes changed?wen to check the oil
this depends on how you drive and how many miles you have on your car and what type oil you are using, on a 1994 you should do a tune up every 30 to 40 thousand miles. You need to do a engine clean then change oil. if you use a good quality oil you can go every 3 to 5 thousand miles on changing oil. You need to change the oil in the drive train after 30 thousand miles and the transmission oil and filter should be changed every 30 thousand miles. Also the Thermostat and antifreeze should be changed every two years to make sure the anti freeze is still lubricating the water pump. Failure to change antifreeze has burt up more engines than I can recall. Check oil in the morning when cold. Check the transmission oil when hot and in park. If you want more detailed information post here.
Sep 29, 2009 | 1994 Ford Thunderbird
My oil light is on, i have 39 miles on my gsxr 600. do i need an oil change or do i need to put oil in
Don't listen to the idot that said to change your oil at 39 miles! If you only have 39 miles on your bike and your oil light is on it mean there is low oil pressure so you need more oil in it. Cause the only reason that light goes on is when theres not enough oil in it. Not because you need an oil change.Also the oil change should be done at least every 3,000 miles but I do mine at 2,500. Also When you change the oil for the first time, you want to change the Filter as well. Every oil change there after you dont have to change the filter every time, you can do it every other oil change if you choose to. And always fill it up to in between the lines of your sight glass. and always makesure that after you put oil in it you start it up and for about 30-60 seconds then shut off and let sit for about an hour and add oil as needed.
Sep 18, 2009 | 2008 Suzuki GSX-R 600
When I put the canon ex40 II in autozoom, it does not show focal length or distance on canon 40D, what am i missing? canon 40D has the latest 1.1.1 firmware
The lens you are using might not support the autozoom. Some Sigma, Tamron and other 3th party lenses are known for these problems. Best solution is to buy genuine Canon lenses, the best partners for your Canon body. (No I'm not related to Canon, I've just seen a lot of these problems with other lenses)
Sep 05, 2009 | Canon Speedlite 430EX TTL Flash
I have an Hitachi ex40 excavator. it has started to nearly stall
I have a EX200-3 it starts but has no power. when I use any function it wants to stall. Except for the bucket function, when i use this function the engine frees up. I brought it to a mechinic but they couldnt find the problem and even made the problem worse. So when I start it up the engine sounds like there is a heavy load on it and ready to stall, this problem began and has become worse to the point I can not use the machine. Help please....
May 26, 2009 | General Garden
No problem, just question on oil change,
I would recommend that you change your oil every 3,000 mile or 3 months which ever come first. This just help you keep a cleaner engine and keeps oil at Peak performance and provide excellent protection against sludge which developes with lack of oil change. Once a year seems too long for an oil change. However between oil changes you can add oil if needed. Good luck and thanks for using FIX YA
Jan 26, 2009 | 2006 Buick Lucerne
2000 Toyota Camry Oil Change
I am assuming that you will be changing the oil filter aswell
if your engine is a 3L you will need 4.7 of Oil
If your engine is a 2.2L you will need 3.9 L of oil
Sep 05, 2008 | 2000 Toyota Camry
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
