Question about Frigidaire Refrigerator White Fridge & Freezer Handle Set - 5304485330
How to fix ice maker on frigidaire plhs67egsbo
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
SOURCE: Frigidaire FRS26ZSH ICE MAKER NOT WORKING
buy a new one .
Posted on Oct 30, 2008
SOURCE: Ice maker not making ice
We do not use our ice maker. But all of the sudden water is leaking from it. Can you tell me how to fix this? Calling a plumber wil cost a fortune.
Posted on Mar 09, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
  • 103 Answers
SOURCE: frigidaire not dumping the ice
Hi: Dumping the ice is the start of the ice making timer. Before you replace the ice maker... Set the freezer one setting colder. The ice maker wont make ice if the freezer is not at zero degrees F. Just because things are frozen in it dosn't mean it is at zero. This happens a lot in the summertime. After resetting the temp don't open the door every hour to see if it makes ice as you will just dump the cold air out. Listen for the ice to dump, give it 24hrs. I hope this helps, Jeff
Posted on Jun 07, 2009
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
I own a Frigidaire refrigirator model PLRS267ZA and the ice maker gets stuck / frozen mid ice making then starts to click because the gears can no longer turn. is there any way to fix this or do i have to...
It is best just to replace the ice maker. there are many small parts in the ice maker. You may be able to purchase just the gears but they are usually a factory order.
Jul 14, 2014 | Frigidaire PLHS267ZA Side by Side...
Why does the ice maker in my Frigidaire model# FRS6HR4HW1 refrigerator not receive any water?
Could be the solinoid valve that lets the water throuh to the ice maker. i I would check the coil on the valve for a curciut
Jun 19, 2012 | Frigidaire Refrigerators
Frigidaire Superba Ice Maker not stopping making ice
-Turn the ice maker off. If still leaking and decide not to use the ice maker to make any more ice then unplug the
water valve that let water run to the ice tray. Only the one for the ice. Otherwise you will not have any water at all.
Good luck
Mai
Mai
Nov 01, 2017 | Frigidaire Refrigerators
Frigidaire Side by Side Ice Maker Not Working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
980
May 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Mar 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire Refrigerator White Fridge & Freezer Handle Set - 5304485330 Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
