Question about RCA D61W20 61" Rear Projection Television
All inputs I have sound but no picture. Menu works fine
All video in all th inputs is not working at all. Got sound and menu, just no video
No menu as well.
Posted on Jun 22, 2009
Sharp aquos 60" TV has sound but only a gray picture. Was fine then, went gray. Help?
Do you see the menu when you press the menu button. If the menu looks ok, then you may have a problem with one of your inputs. Try a different input port and change the TV to that input. Also try a new cable and try a DVD input or other video source to help isolate the problem.
Feb 12, 2015 | Sharp Televison & Video
I have a 56inch panasonic Viera LED TV. it turns on and the sound works fine, and the screen lights up but it is a white blank screen with no picture. Suggestions?
Does it display channel numbers or other pictures when you press menu or other tools? If so, it's a problem with the TV's video inputs. If not, it's something wrong with the projection hardware, matrix, or power supply. Failing that, I recommend contacting Panasonic's support center, and keep any information you have on buying the TV handy. Good luck!
Dec 06, 2013 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH-58PZ700U, has sound, no picture on any input. Will show photos from photo card inserted into SD card slot. One person said it may be the A board.
Ur tv still able to see picture photo on ur tv video functions,tv should be still able to work.Tries tv and cable or satalite boxes unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting and those pay boxes to reboot and upgraded it softwares.U have the tv original remote?Yes?Push the tv menu button if ur tv have a video menu than it is a very good new.Tries tv resetting every modes on the tv Menu back to factory setting.Tv should funsctions again.After tries to resetting the tv and rebooting those pay signal boxes,if tv still getting no tv video signal.Than those tv backlight buffer boards for the Plasma screen X or Z are dead could be either X or Z or both.Find the closed it is authorize LCD and Plasma tvs shops for repair.Best because they have the equipments to determine the exact buffer board is or are dead.
Aug 17, 2011 | Panasonic TH-58PZ700U 58 in. Plasma HDTV
TV's picture and sound goes off. Had to cycle Mitsu WS-55513
THERE IS, aside from having the set taken to a shop, One other thing you can try---
NOT THE RESET BUTTON ON THE FRONT OF THE SET!
If the original Mitsubishi remote works on the set---this set has a hidden menu---it also in that menu has a HARD RESET---puts set back to the condition is was when new in the box--will come back on on channel 3 in the air band and any labels you placed on any of the video inputs (ie--named a input DVD etc) will be gone.
If you have OSD but no video either you have some problem with a single voltage coming out of the power supply(shop repair) or if you had a power outage or the power cord was removed with the set on---the hard reset may fix it---nothing to lose--set is not usable now---
Let me know if you want to try the reset and I will tell you how----
REGARDS, SD TECH
Oct 26, 2009 | Mitsubishi WS-55513 55" Rear Projection...
No picture, good sound
It's most likely the video board. The menu is injected at the output of the video stream right before the LCD panel. Having audio indicates the signals are getting from the inputs through the input switcher and audio boards. Unless you have electronics experience, I suggest having an experienced tech look at it.
Apr 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Video input
There may be a child lock feature on your set but you would not get sound or picture. If you can not get a picture from the video input jacks and the set works fine other wise then this - sounds like a problem with the Video switching circuits inside your television. I would refer this type of repair to a qualified technician.
Jul 29, 2006 | Toshiba 57H81 57" Rear Projection...
RCA D61W20 61" Rear Projection Television Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
