Question about JBL Northridge E 250P Subwoofer
How to repair jbl norhridge E series subwoofer
Sub gets switched on but no output even after increasing the sub vol. is ther any problem on circuit board
  • Anonymous Jun 16, 2017
    My E250p sub worked great for 2 years but I always had the tube on the bottom falling out every time I used it. So I glued it in and it seemed fine, but now when I turn it on there an extremely loud deep base sound just for a second and air shoots out the bottom tube. No matter how many times I shut it off and turn it on it goes BOOM! It also sounds like there's a rattleling sound when I use it. All the screws are tightened so I am confused. Please help.
5 Suggested Answers
  • 29 Answers
SOURCE: i got a jbl sub
Have you checked the Impedence of the old speaker. If you can measure to below 8ohms you need not replace the speaker. Check with proper LFe signal at input of your amp. Also check for power indications before going further.
Posted on Dec 16, 2010
idrvnsx2
  • 60 Answers
SOURCE: need a replacement amp circuit board for a jbl
The boards can be repaired - look for we repair and your model number on ebay -
Posted on Nov 03, 2011
idrvnsx2
  • 60 Answers
SOURCE: One of my circuit boards is blown (104 sub 15000
You can purchase repair on ebay - look for the auction under JBL VENUE SUB10
Posted on Nov 11, 2011
idrvnsx2
  • 60 Answers
SOURCE: how and where can I
There is a guy on Ebay who repairs these - not sure but I don't think the board is available - you could check with Harmon - they own Infinity and JBL
How and where can I get a circuit board for jbl venue sub 10
Aug 18, 2011 | JBL Venue SUB10 Subwoofer
Need a replacement amp circuit board for a jbl venue sub 10 - part # is 104HKTS1400v-E
Nov 22, 2009 | JBL Venue SUB10 Subwoofer
Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Nov 17, 2009 | Velodyne SPL-1000 Subwoofer
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
My sub has no power, ther could even be other problems i'm not aware of. so i would like to fix power first
Hiya, start by checking the power cable, then check the fuse in the unit on the pcb. If blown, replace and if it blows again then problem could be either Power supply or the amp outputs. If it doesnt blow, stays on but no sound, problem also likely to be output stage. You will need someone with experience to check outputs, etc and a meter though. Hope that helps a bit.
Best of luck
Jul 15, 2009 | JBL PSW-D110 Speaker
Even Distribution
i have same speakers try these setting and tell me what you think put phase at 180 and put switch on lfe mode not normal for some reason my sub plays louder on these setting verse phase on 0 and lfe switch on normal i have power on subwoofer a little more than half also set croosover to 80hz you will never touch it again
Dec 05, 2008 | JBL Northridge E 250P Subwoofer
Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
Sep 03, 2008 | JBL Northridge E 250P Subwoofer
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenterâ„¢ SW 200 with Clean Powerâ„¢ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
JBL Northridge E 250P Subwoofer Logo
161 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
