Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
I'm trying to connect a WDTV to my SAMSUNG LE32R74BDX by HDMI but the HDMI source isn't found by the TV, it simply stays greyed out, should devices like this be plug and play or am i missing something? thanks!
    New Friend:
I'm having same problem but what u mean with composite cable? I tried everything still greyed out.. Worked last week but think I pressed something.. Any further assistance wud be appreciated
Posted on Aug 21, 2014
  • 3 Answers
I had the same problem. Had to connect using the composite cable, when to settings, changed it to HDMI. This turn the display on my TV off again. Then plug in the HDMI and it worked!
I also expected it to be plug and play... Hope this works for you...
Posted on Sep 02, 2009
When selecting the source, HDMI 2 will not highlight, Only TV. HDMI cable connected to box and to HDMI2 port on TV
You have to check the HDMI cable. In Samsung tvs the HDMI sources only highlights if the a proper HDMI sources is connected to the corresponding HDMI port of the tv. Also check by connecting any other device which have and HDMI connectivity to the HDMI 2 port.
www.electro-medical.blogspot.com
https://www.facebook.com/electromedservices?fref=nf
Oct 02, 2015 | Samsung UN22F5000AF 22 LED 5000 Series TV...
I'm trying to connect my ps3 to my samsung le32r74bdx but when i connect the cable's either by the scart lead or the hd cable i get no home page from my ps3
yes use hdmi cable or counpounts ? tell ps 3 only 720 p on this samsung max out puyt dont use ps3 in 1080 p mode in video settinsg ok
Oct 15, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
How do I connect tablet to tv
select on tv menu the hdmi source and the game is done
Mar 10, 2015 | Samsung Tab Tablets & eReaders
Silver crest tv
This sounds like the Silvercrest TV is not recognising the netflix. They may not be compatible, but I don't know why they wouldn't be. If there is any other way to hook it up such as RCA plugs or coax adaptor then try those. However before I did that I would work with programming the TV. By it starting to load then giving you a blue screen it means that it started to load and lost all signal input. The Blue screen as you probably know is what we used to call 'raster'. It is what the TV shows when it has no input. The TV is sampling the input and not finding anything that it recognises and dropping the download attempt. The WDTV has a different format than most other devices. See if the Silvercrest has a special function in the menu for WDTV if not I would try some other hook up such as the RCA Jacks if possible. Check your service manual on the TV or Netflix and see if either mentions any thing about the WDTV. You may need an adaptor. If you are like me and don't have the service manuals then you can go on line and see if the TV will run WDTV. I'm thinking I had a problem I had a problem with WDTV adapting to some kind of a TV and the best I remember I had to get s special adaptor for it. It has been a long time since then. I do know that the WDTV's frequencies are different 'the ordinary frequencies that is use with normal broadcasting. Let me know how it turns out.
Mar 15, 2014 | Netflix Computers & Internet
My samsung HD tv keeps skipping when I press the source button. I can't get it to stay on HDMI. A message comes up saying" check signal cable "
could be on one of 2 problems.either means ur hdmi cable is faulty or that u should try resetting ur hdmi device/try unplugging ur hdmi device for a few minutes.
Oct 06, 2013 | Televison & Video
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
559 people viewed this question
Jerry Greenberg
Jerry Greenberg
