Question about Gear One PA2400 / Kustom KPC15 PA Package
How many amps does it pull?
Amps with four speakers
How to bypass 2001 Chevy impala factory amp.
You need a volt /ohm meter. Pull the radio. Cut the tape off the harness, find the twisted pairs of wires (look at the colors of them). These are the speaker wires. Go to the amp and find those wires. Cut them loose. Look at the speakers wire for the rear dash. There is four of them. Measure the resistance of one speaker. You need this number to find the front speakers/wires. Once you find the wires, If you want to match the radio to control front/back/left/and right. You have to adjust the radio and match the speaker wires. I have yet to find a matching schematic to this.
Mar 19, 2016 | Cars & Trucks
Amp turns off.
your drawing/pulling too many amps. Is it a mono(one speaker), two way(two speakers/can be briged to one), or a four way(four speakers/can be brigrd to two). don't put too many speaker to that one amp if it's only a mono, or a two way.
Sep 24, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Having problems with the installation of the brutus 2008d amp in my truck. how many channels is it? how do i connect the subs? do i connect the rca cables from the radio to the input or output.
The rca cables from your stereo go to the "input" part of the amp. Now, if there are four speaker connections in your amp, then it's a 2 channel. If you have eight speaker connections then you have a four channel amp. Note, some amps can be briged to provide more power to the speakers. On a two way amp(2 speakers), the connections can be briged to only one speker providing more power, usually whatever the amp power rating is, say a 500watt amp will put all 500 watts to that speaker. The same goes for a four way amp(4speakers), can be bridged to two speakers(250watts per speaker). Hope this helps.
Sep 04, 2009 | Car Audio & Video
CORRECT CONNECTION TO AMP BEING A FOUR TERMINAL SPEAKER
Hello i_starling,
The Kicker L7's come in either 2ohm or 4ohm dual voice coil (DVC) versions.
Whatever amp they are connected to, you need to know both the impedance of your L7's and the impedance of your amp. The L7's dual voice coils can be wired to provide a total of four different loads:
2ohm coils in parallel = 1ohm load
2ohm coils in series = 4ohm load
4ohm coils in parallel = 2ohm load
4ohm coils in series = 8ohm load
Your best connection would be the one that results in a final impedance load that is supported by the amp.
Hope this helps.
May 01, 2009 | Car Audio & Video
Volume low on all four speakers, some static (amp or head unit problem)
I would check the amp first, especially if you have very low sound on the speakers. Before amps were made, bad output transistors would create the same effect.
Apr 13, 2009 | 1997 Chrysler Sebring
Bass amp not turning on: 2001 ford mustang convertable V6
hey you battery might be going low or some fuse might not be pushed in all the way if its not that then you probably got a blown amp
Nov 30, 2008 | 2001 Ford Mustang
Sony cdex-m630 connections with an amp
You can use either set of RCA outputs for the amplifier that you want to. Only difference in either of them is front, rear and sub outputs. If you are only powering a sub amp, then use the sub outputs, otherwise, the other two will work fine. You can still use the outputs from the radio itself to power four other speakers while using the RCA outputs.
Jun 26, 2008 | Sony CDX-M630 CD Player
Adding a woofer to a 4 channel amp with 4 speakers
well yeah thats what im doin riht now in my ford taurs what u do is u can hook up your 5x7s and ur 6x9s on ur amp sill have room for a sub the way too do that is get the front speakers off the amp just run the back andsince its a four channlel amp 1 and 2 channel are used for the back and 3 and four are used for thesub of couse u brige the sub to the amp 3 and four are used for the sub hope that helps friend let me no what happens
Apr 08, 2008 | Car Audio & Video
Speakers
You have A and B output on your amp.For example you can connect two speakers on A and four on B but first check impedance of the speaker.Use four pioneers but make serial connection (+ wire of one speaker goes to +Rout,-of that speaker goes to + of another one and then its - to -Rout of the amp.Same thing for left channel.Thats for B output.For A simply connect speakers.By choosing A or B ON or OFF you'll get two or four speakers working.If A and B is ON all six will work.I hope that this will help you
Feb 29, 2008 | Audio Players & Recorders
Gear One PA2400 / Kustom KPC15 PA Package Logo
80 people viewed this question
Top Gear One Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Gear One Audio Player and Recorder Expert? Answer questions, earn points and help others
