Question about NorStar Meridian M7310 Phone
Line buttons showing wrong phone lines
We use 6 phone lines, but have an additional 7th and 8th line we could use but are not set up with the phone company. Now one of our phones is showing line 1 as line 4, line 2 as line 5 etc... Line 6 shows as "make calls first", and the page button  always dials a number previously dialed earlier on in the day. How can I correct this.
  • NorStar Master
  • 2,460 Answers
When a phone has only 2 lines, it's not programmed. By default, a Nortel system has 2 lines and that's all. Go into system programming and assign the number of lines and intercoms to a phone. After that, you can copy the buttons from a working phone to the new phone and you're done.
Carl
Posted on Jun 22, 2009
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Tip
    Check Your Mobile Quality!
    Press the following on your mobile *#06# and the-international mobile equipment identity number appears. Then check the 7th and 8th numbers:
    -------------------- 1 2 3 4 5 6 7th 8th
    Phone serial no. X x x x x x ? ? ? X x x x x x x
    IF the Seventh & Eighth digits are 02 or 20 this means your cell phone was assembled in Emirates which is very Bad quality
    IF the Seventh & Eighth digits are 08 or 80 this means your cell phone was manufactured in Germany which is fair quality
    IF the Seventh & Eighth digits are 01 or 10 this means your cell phone was manufactured in Finland which is very Good
    IF the Seventh & Eighth digits are 00 this means your cell phone was manufactured in original factory which is the best Mobile Quality
    IF the Seventh & Eighth digits are 13 this means your cell phone was assembled in Azerbaijan which is also very Bad quality
    on Aug 30, 2009 | Nokia 9500 Communicator
    Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
    Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
    Jul 27, 2010 | Fisher and Paykel Washing Machines
    I NEED TO SET UP 4 PHONES TO HAVE A LINE 5 AND A LINE 6. THE BUTTONS FOR THE EXTRA LINES ARE PROGRAM WITH SOMETHING ELSE. HOW DO I PROGRAM THE PHONES TO HAVE LINE 5 AND 6.
    Programming is done on M7310, M7324 and T7316 sets.
    To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
    At the terminals&sets prompt,
    press the show key (top right arrow).
    The display should now ask for an extension number. Enter extension number you wish to program ringing on.
    Press the show key (top right arrow)
    The display should sat LINE ACCESS
    Press the show key (top right arrow) .
    The display should say LINE ASSIGNMENT.
    The display ask for a line number. press list
    The display should say line 001: appear & ring
    press the next key (bottom right arrow) till it says 025(or 031):unaaign press the chng key till the screen says appear&ring
    Press the next key(bottom right arrow)
    The display should say line 026(or 032): unassign
    repeat the procedure the same as line 5 for line 6
    press the release key when finished
    Jun 23, 2010 | NorStar M7310 Corded Phone
    You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop. How though?
    Changing programming on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
    1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
    2.- Enter password (default = 266344) - display should read "Terminals & Sets"
    3.- Press "NEXT"(bottom right arrow) - display should read "lines"
    4.- Press "SHOW" (top right arrow)- display should ask for a line number
    5.- enter in the line number you wish to change the supervision on in a 3 digit format. ex. line 1 = 001
    6.- press the show key (top right arrow)
    7.- The display should say Trunk/line data
    8.- Press "show"(top right arrow) - display should read "trunk type"
    9.- Press the next key (bottom right arrow) 7 times"
    10.- the display should say "trunk mode: unspr"
    11.- Press softkey "CHANGE" to "super"
    repeat steps 5 - 11 for the remainder of the lines Press the Rls key when finished
    Nov 03, 2009 | NorStar M7324 Telephone
    I have four samsung hdd in warranty i want to replace plz give me service center at delhi and phone no
    dear,
    hope it will work
    Head Office:
    Samsung India Electronics Pvt. Ltd.
    7th & 8th Floor, IFCI Tower
    61, Nehru Place, New Delhi-110019
    Tel: (91-11) 41511234
    Fax: (91-11) 41608818/19
    Contact Centre:
    Toll Free No: 1800-110-011
    (From MTNL/BSNL Lines)
    Tel: 30308282 (Prefix Local STD Code)
    The Official Samsung Website:http://www.samsung.com/in/
    goodluck...
    Sep 03, 2009 | Samsung SpinPoint M80 80GB 5400RPM SATA...
    Norstar m7310 I would like to set more phones to ring
    To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
    At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
    The display should sat line 001: appear only press CHNG til it says appear &ring.
    press next key (lower right arrow)
    The display should say line 002: appear only
    Repeat same procedure as line 001 til all available lines are done
    if the programming doesn't look like 1 described call me @1.410.984.4840
    Mar 25, 2009 | NorStar M7310 Corded Phone
    Panasonic TVS50
    sorry...i don't think it's possible,it will only answer on 7th or 8th ring
    thank you...
    Aug 19, 2008 | Lands Phones
    AT&T Spirit Phone
    You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
    First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
    After moving the admin switch, and before dialing Ftr 7 -
    From station 10 press intercom, Press speaker, Dial *0, Dial 1, Then Press Ftr 7.
    Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
    dialing.
    To change the dialing type for a line or lines, press the line button(s) and dial the appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
    Be sure to turn the admin switch back off when you’re finished.
    Aug 05, 2008 | AT&T Spirit 6-Button Stard Misty Phone
    There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
    Press speaker,
    Dial *0,
    Dial 1,
    Then Press Ftr 7.
    dialing.
    Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
    NorStar Meridian M7310 Phone Logo
    349 people viewed this question
    Top NorStar Lands Phones Experts
    Marvin
    Marvin
    Oloyede Monsuru
    Jose Ma DM.
    Jose Ma DM.
    Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
