Question about GE JBP30 Electric Kitchen Range
GE electric range JBP30 bake element not working. Replaced element still now working. Was told the only otheer thing it would be is clock. Is this correct?
the dr
  • 447 Answers
SOURCE: GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Posted on Nov 16, 2007
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
  • 29 Answers
SOURCE: ge range electric oven won't heat up
WHEN BAKE CYCLE IS SELECTED?
Posted on Jan 29, 2009
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
SOURCE: Clock on a GE electric range is buzzing - how to disconnect it
Turn off power to range first!!!
You'll have to remove the back of the panel in which the clock is installed to access the back of the clock. There will be two wires attached to the clock. Just pulling one of these wires off will stop the clock.
I would suggest, however, that you pull both wires off, put electrical tape on the ends of the connectors, and tuck them out of the way somewhere around the clock.
Posted on May 03, 2009
Why doesn't GE JBP24 preheat?
Not familiar with this exact range, but it could be a couple of things.
If the broiler (upper) element heats properly and the baking (lower) element works properly, then the issue is probably in the controller/preheat switch.
If the broiler doesn't heat up, then the upper heating element.may need to be replaced.
Jun 15, 2014 | GE JBP24 QuickClean Electric Kitchen Range
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
May 03, 2009 | GE JBP30 Electric Kitchen Range
Eric Campion
Feb 15, 2009 | GE JBP30 Electric Kitchen Range
Oven problem
if you had a power surge then the resistors on the board cannot handle it. i am no electronics expert however i am a range expert and usually it happens when 1 you live in a very rural area and have frequent power surges.. 2 get struck by lightning.. 3 may have a miswired outlet.
Jan 20, 2009 | GE Profile 30" Free-Standing 5 Burner Self...
JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Dec 15, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Bottom element on range doesn't work
we can check a few things, first off you need to confirm 220v. to unit itself, ill assume you do, the top elements are working correctly.. sounds like a bad electronic control, what youll need to check is on the control itself, there is a wire labeled L1, then there will be a bake terminal, ill also assume L1 has 110v, other\wise the clock wouldnt be liting up, but if you carefully unplug the bake terminal and test terminal for power( it will have 110v, after you select bake andstart oven.
Nov 17, 2008 | Amana AER5515QA Electric Kitchen Range
Baking element
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Oven not working
Sounds like the oven control which is the clock is bad. The relay for the bake element has probably gone bad and will need to replace the control. You should check continuity on the bake element. If it shows resistance then it is ok. Also, on some models the overlay for the oven control is a separate part. If it is you will need to buy it also.
Oct 09, 2007 | GE JBP71 Electric Kitchen Range
GE JBP30 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
