Question about GE JBP30 Electric Kitchen Range
I have Ge model #JBP30BA2 baking element is not working. Was told the only other part besides new baking element it could be is clock. Does the clock also control baking element?
  • 23 Answers
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
It sounds like the controls have been placed into a lockout mode. If your model is a JGBP79 do the following:
1) Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the
display shows SF.
2) Press the SELF CLEAN pad. The display will show LOC OFF.
Now here is where the directions are kind of confusing, I will give it as they say it:
3) Press the SELF CLEAN pad again. The display will show LOC.
4) Press the START pad to activate the control lockout feature and leave
the control set in this special features mode.
Seems to me if its locked already, you would just do steps 1 and 2. And if you wish to lock it do steps 1 thru 4.
Posted on Jan 27, 2008
revamos
  • 16 Answers
SOURCE: Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Posted on Apr 21, 2008
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
duby1990
  • 367 Answers
SOURCE: ge spectra jbp64, replacement bottom bake element
Take the 2 screws out of the back wall of the oven (inside) holding the element on. Then pull the element out and it will expose the wires and terminals (2). Unplug the 2 wires and plug them on the new element and mount the element back in the oven and your fixed. (make sure to turn the power off to the oven before you start unpluging wires.
Posted on Nov 21, 2008
SOURCE: ge stove bottom element not working (top working)
The bottom element has probably "blown" out. See if there is a small spot that looks like it exploded. It is similar to an extension cord getting warm and melting in a spot. The only answer is to obtain a new element.
Posted on Dec 18, 2008
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
Bottom oven element not working
Only 2 things left. A bad wire or bad control board.
Remove the rear panel. Set the range to bake,check power at the element terminals with a voltmeter. Ifyou do not have 220 volts at the element replace the ERC.(clock).
May 23, 2009 | GE Ovens
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
Oven problem
if you had a power surge then the resistors on the board cannot handle it. i am no electronics expert however i am a range expert and usually it happens when 1 you live in a very rural area and have frequent power surges.. 2 get struck by lightning.. 3 may have a miswired outlet.
Jan 20, 2009 | GE Profile 30" Free-Standing 5 Burner Self...
JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Dec 15, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Baking element
Hey there. make sure the clock in on manual and not automatic is should show a little hand and not a 0 :)
Sep 05, 2008 | Kitchen Ranges
Baking element
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Oven not working
Sounds like the oven control which is the clock is bad. The relay for the bake element has probably gone bad and will need to replace the control. You should check continuity on the bake element. If it shows resistance then it is ok. Also, on some models the overlay for the oven control is a separate part. If it is you will need to buy it also.
Oct 09, 2007 | GE JBP71 Electric Kitchen Range
GE JBP30 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
