Question about Vtech IP5850 Answering Machine
How to turn announce only feature off ? - Vtech IP5850 Answering Machine
How can i turn off call announcement feature?
go into your settings & tools then go to sound settings and scroll down to driving mode and set your driving mode to off and that should fix your problem.
Feb 05, 2016 | Samsung Convoy Cell Phone
How do you turn off talking caller ID on panasonic kx-tg4032?
This feature lets you know who is calling
without looking at the display.
To use this feature, you must:
- subscribe to a Caller ID service of
your service provider/telephone
company.
- turn this feature on (page 24).
When caller information is received, the
handsets and base unit announce the
caller's name or phone number received
from your service provider/telephone
company following every ring.
The unit announces in English only.
L Name pronunciation may vary. This
feature may not pronounce all names
correctly.
L Caller ID service has a limit of how
many characters can be displayed. If
the caller's name is too long, the
handset may not be able to display or
announce the entire name.
L The announcement is heard at the
same level as the ringer volume (page
16, 23).
L If you turn on the answering system
and set the number of rings "2
rings" (page 36), the unit does not
announce the caller information. If
"Toll saver" is selected and there
is a new message, the unit does not
Mar 24, 2011 | Panasonic KX TG4032 19 GHz Twin Cordless...
I have a LG 220 C phone and I am trying to figure out how to deactivate the announcement feature on the phone. My phone is not ringing; it is just announcing the incoming caller's phone number.
Go into the menu. Then hit '8' (calendar, alrms, etc I think?). Press '1' (voice commands). You will then get a drop list to check or uncheck regarding 'deactivate', 'announce', 'announce +ring'. Select deactivate-- now your phone will ring normal! Son had same prob on his phone-- apparently he'd hit 'announce' at some point....
Jan 27, 2011 | LG C 2200 Cellular Phone
How do make the gps announce the street name to
Neither the Nuvi 250W nor the Nuvi 205W have Text to Speech (which is the feature that allows the unit to speak the street names), so you cannot make yours speak street names. I'm sorry.
Jul 21, 2010 | Garmin nuvi 205W GPS Receiver
Had to reset the phone. on in-coming calls it used to say the persons name, where is that set-up
LG Xenon - for adjusting the audible caller announce feature: hit the options menu in the top right corner and select call alert, you can set the phone to announce the name or number of the person calling/texting before the ring.
keywords: call, caller, audible, announce, announcement, announcing, loud, alert, name, person
Nov 13, 2009 | LG Xenon GR500 Cell Phone
KX-TG9344
This is the info from the users manual, it seems a bit strange,
but claims if you set the number of rings before it answers, (for the answering system) to "2" it will stop the audible caller ID.
Here it is from the manual.
and set the number of rings “2” (page
38), the unit does not announce the
caller information. If “Toll saver” is
selected and there is a new message,
the unit does not announce the caller
information.
When you receive a call while on the
phone, the 2nd caller’s name is not
announced even if you subscribe to
both Caller ID and Call Waiting with
Caller ID services
Jan 02, 2009 | Panasonic KX-TG1033S Cordless Phone
Goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdf
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
Dec 26, 2008 | GE Security Simon 3 Wireless Home Security...
Street names no longer announced
The 200W isn't supposed to have text-to-speech (where it actually speaks the street names). If yours did initially it was probably loaded on the unit by mistake at the factory. That feature isn't part of the 200W or it's software.
Oct 31, 2008 | Garmin nuvi 200W GPS Receiver
Not working
Astonishingly, assignment of announcement to phone line is not documented in the user manual. Tech support was totally worthless concerning this issue. I had to discover it by trial and error. To assign an announcement to a specific phone line do the following:
1) Record your announcement message for a, b, c, ao, etc. as documented
2) Press program
3) Keep pressing the feature button until ANNC appear at the bottom of screen, line 1 appears at the top, and the letter 'a' appears in the middle.
4) Choose the announcement to be assigned to Line 1 by pressing the select button
5) Press the feature button again. Line 2 appears in the display.
6) Repeat step 4 to select the announcement to be assigned to Line 2.
7) Press program button, or take phone off-hook to end the sequence.
Shame on AT&T for such shoddy documentation, and lack of support for their products!
Nov 09, 2007 | Lucent 1872 Corded Phone
Vtech IP5850 Answering Machine Logo
15 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
