Question about Delta 36-716B 10" 1-3/4 HP 120/240V Induction Left Tilt Hybrid Saw w/ 30" Unifence
My table saw stops after a minute or two i replaces the capacitor and still does the same the breaker pops out
  • 40 Answers
The motor or bearings are bad if it is stopping under a load while getting hot
Posted on Jul 03, 2009
    President:
  • 1,723 Answers
This means it's drawing high amp. Could be just packed with saw dust, getting hot. The breaker is probably thermal. Clean it up good. If it still trips, check for name plate current on motor and test.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
Table saw keeps tripping breaker
May have a brush in the motor that's hanging up or worn may try
replacing the brushes
Feb 07, 2014 | Saws
I have to push blade to start and after a little while breaker trips
The Start capacitor is bad. (CD60A) Made in China the min. order is 1000 peices, replace motor cost more than the saw, or get a 200 uf 250vac capacitor (Grainger) to replace the CD60A. It is larger so you have to mount it on top of the external cap on the motor. I think the CD60A is going to be a major problem on all these saws.
Feb 18, 2013 | Craftsman 10" Table Saw
I have a Bosch 4000 table saw when I start it will not rev up to full speed and after a min. or two the blade will **** to a stop and make a clicking sound then start up at half speed then immediately...
The field coil sounds like it has failed, best to find a service cneter in your area, this is a very involved repair if you are not familiar with these units.
Jul 05, 2011 | Bosch 10" Slide Miter Saw
Trying to cut any size piece of wood the saw blows the circuit breaker at the panel 1x4 piece
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
Apr 13, 2011 | Craftsman 10" Table Saw
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
Grizzly go691 10" table saw.
Make sure the motor is not bound-up by turning the shaft somewhat. Suspect a faulty power switch for the motor, also check for a thermal breaker on the motor--push to reset. It is not likely that the motor windings could have gone bad. Does the motor 'hum' when turned on? A start capacitor could have failed in that case. Contact the selling dealer for warranty help if you can't get it running again. Hope this helps!
Nov 19, 2010 | Garden
20 amp Circuit breaker trips everytime I flip the motor switch on. Its a craftsman table saw motor 1HP Model 113-12070., 14/7 amps
I assume that you are using the motor on 115 volt service. Remove the drive belt and check for excess friction in either the saw arbor bearings or the motor bearings. If both seem free to turn, then suspect that the start capacitor on the motor has failed. They usually become open circuited which prevents the start rotation. It will just sit there and hum loudly until the breaker pops. You may also have a defective 20 amp breaker--you will need a clamp-on AC ammeter to verify. Suggest that you run the saw on 230 volt service when you get it running. You will be amazed at the acceleration and apparent power available. My table and radial arm saws are both set for 230 volt operation and love it. Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of drawings that list all replaceable parts. Hope this helps!
Jun 27, 2010 | Craftsman 10" Table Saw
Start capacitor keeps blowing. saw starts up
SOUNDS LIKE THE CENTRIFUGAL SWITCH IS NOT WORKING.
THE MOTOR IS STARTING ON THE START WINDING AND NOT SWITCHING TO THE RUN WINDING. THAT IS THE REASON IT IS RUNNING SLOW.
May 13, 2010 | Diamond Products Mk - 101 10" Tile Saw
Delta table saw motor trips breaker
The motor needs a new start capacitor.
Apr 09, 2009 | Saws
My saw wont run only buzz
Sounds like teh capacitor has blown. These machines use normally use induction motors so they need the capacitor to take a charge and give the motor a kick in the right direction. You could CAREFULLY turn the machine on and spin the blade by hand. If it runs now then you will need a new capacitor.
Oct 14, 2008 | Saws
Delta 36-716B 10" 1-3/4 HP 120/240V Induction Left Tilt Hybrid Saw w/ 30" Unifence Logo
403 people viewed this question
Top Delta Saws Experts
Craig Butler
Craig Butler
Ronny Bennett Sr.
Ronny Bennett Sr.
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
