Question about Hisonic hs596 dual wireless lapel & headset system
Both my hand mics just went dead after a year but the lapel are working what could be wrong
Why won't wireless mic turn on the "Ready" light on receiver?
Make certain the mic and the receiver are in the same exact frequency band. There are stickers on both products that list the frequency band.
Apr 27, 2012 | Shure UT2 / 58 / PG58 Professional...
The handheld is in a different frequency band than the receiver. There are stickers on both that saw what frequency range they can tune to.
How do I connect my audio-technica lapel mic to a device with an amplifier
I imagine their website may address that for your unnamed specific model ('lapel' isn't specific); and/or the manual that came with the amp. Most mics need preamps.
http://www.audio-technica.com/cms/site/1635df9c8c5039f1/index.html
Jun 23, 2011 | Audio Players & Recorders
I need to purchase a lavaliere type mic for my passport 150 and I am not sure what I need, It comes with a hand held ireless mic but I want to use a lapel type.
Wireless systems can be purchased as either lapel or handheld systems. Talk to the dealer that you are purchasing the wireless from and let them know you want a handheld system.
Apr 13, 2010 | Lectrosonics FENDER PASSPORT PD-150 + 1...
Audio Tech at831cw lapel mic wires disconnected
normaly when pulled out the cable is also come inside defective, probably better a new mic spare. you can spend time repairing and still no working well
Jan 02, 2010 | Audio Players & Recorders
Transmit button on the lapel mic will not key the radio
Two things which come to mind, one would be if the PTT on the remote mic is bad/defective, second would be you are plugging the audio device in with the radio turned on.
If your remote mic is failing, the PTT is a repairable item, as is the cord on most models.
Mar 30, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
All four hand held systems failed
check out override frecq see if you can change transmit and recieve switch settings ie dip switch sets sombodys overiding your freks
Dec 17, 2008 | Sennheiser Evolution G2 100 Series UHF...
All four hand held systems failed during a performance
Hi kb
That is an odd encounter, and most probably one of the R.F.I. kind. Radio Frequency Inference can be caused by many things. Sometimes it can be a nearby piece of equipment creating that much interference, that the mics could not operate. It may have been a spurious mobile radio transmitter as used with two way radio for the cops, ambo's, firies,or even a nearby Cab!! Some times faulty light dimmers can also spray RF.
To what ever end, the fact that 4 mics went down together is indicative of an external problem, and being radio mics, it would have been radio interference.
The only other thing to check is that they are UHF. there are many VHF mic systems still about, but these frequencies are now being used as part of the soon to be introduced digital TV transmission. Best check that they are UHF, The VHF type have actually been illegal for a number of years Hope this info has helped you understand your problem. I am happy to answer any questions you may have. Cheers
regards
robotek
Labtec verse 504
If you are using skype, go to the upper left hand top and click on call. Then click on audio settings and make sure your microphone is listed as the mike to use in the window of the drop down menu. It should say logitech something in the window that says microphone.
Jan 21, 2008 | Labtec Microphone Microphone
Missing Audio
sound changes to external mic. when any ex. mic. is inserted the internal mic. comes out of order then you don't and can't have two sounds same time that mean you only get the ex. mic sound regards please don't forget to rate thx
May 02, 2007 | Canon MV630i Mini DV Digital Camcorder
Hisonic hs596 dual wireless lapel & headset system Logo
14 people viewed this question
Top Hisonic Radio Communications Experts
eradiostore
eradiostore
Are you a Hisonic Radio Communication Expert? Answer questions, earn points and help others
