Question about Water Heaters
Rheem he119-199n water heater Code panel is flashing f09 it has to keep being reset
2 Suggested Answers
  • 13 Answers
SOURCE: rheem model 41vrp40n power vent water heater won't
"Pres sw open" means there is insufficient air flow. either the vent if blocked, or the blower turns too slow/ or died.
Posted on Feb 12, 2010
I have a Richmond tankless water heater and it has L1 error code...can somebody help me with this?
Might be able to help. Except L1 does not show on any error code file.
Copy following link for Rheem Richmond Ecosense etc computer water heater troubleshoot resources
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Are you sure the error is not IL? Delime tankless.
Or UL flashes and indicates reset.
Or CL flashes and indicates fault history is cleared.
Or error 11 combustion failure? Call for service.
Or P1? Low water pressure, clean water filter check for leaks and crossover caused by bad single-handled faucet cartridge.
I recommend calling Rheem to find local technician who is qualified to work on tankless computers. Tankless are not ordinary water heaters, and they require continual maintenance to avoid common error codes, especially as unit gets 2-3 years old, after warranty has expired.
The required maintenance and expense of repairs, and general fact that people cannot make their own repairs, make tankless computers a bad choice for heating water.
If unit is 4-5 years old, it might be best to install tank-type heater for $385 from Lowes and cut losses.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 08, 2013 | Rheem Richmond Encore Tankless Nat Gas...
Rheem water heater flashes seven times ,it is in lock out mode
You have Honeywell electronic gas control valve, and error code is 7 flashes.
Probably you have power vent model.
One manual from different company says: "Reset gas control using on-off button on front of control, replace flammable vapor sensor, replace gas control thermostat.
But with Rheem you also need specific steps: Remove gas burner and look for broken glass vial, and then blow out arrestor screen air intake using compressed air, clean burner parts, check for unobstructed venting, you will need new glass vial from Rheem depending on year and model number of water heater that appears on label on side of unit, or they may not have a repair kit for that model, and you might need a new gas control valve depending on model and how extensive problem was
You have Rheem water heater.http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 28, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
My hot water heater keeps kicking off and the theramsatic is flashing C7 76. How do I reset it?
Use following link for Rheem tankless troubleshoot:
I believe error code C7 is same as error code 76
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Rheem Tankless Hot Water Heater...
The water heater cuts off every night while taking bath. The water turns cold and up to the attic we go to reset. A code of C713 is flashing.It also is flashing the code 1L after resetting. This is a Rheem...
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the error codes
The manual will also have the error codes.
The person who installed the unit will also know the error codes (or should know)
Each day I see 20-25 unanswered questions about tankless water heaters.
The number of questions shows the complexity of the machines, and the inability of the manufactures to take care of their customers.
The manufacturer will refer you to the installer.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.rheem.com/products/tankless_water_heaters/
The link above goes to Rheem tankless water heaters
Click on a product and it opens a page showing many tankless models
Click 'more information' and another page opens with spec sheets and other pdf
Not surprisingly there are no troubleshooting steps or troubleshooting flowcharts
There are plenty of ways to buy a tankless
There are not many ways a do-it-yourselfer can fix a tankless
Oct 30, 2010 | Rheem Tankless Hot Water Heater...
Just bought a water heater with electronic lighter,will not light
check comp board for led light and a reset on board ??? LED will also flash and give code with problem look for code on door panel or close bt and fallow instructions????
Oct 20, 2010 | Rheem 81VP6S/430126 Water Heater
The control unit needs to be reset when I loose power
have two boilers one a rheem the other raypak, the raypak keeps turing off i have to push the reset button. what could be wrong
Dec 30, 2009 | Rheem Paloma Tankless Water Heaters...
Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Oct 04, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
275 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
