Question about Hasbro Nerf Lazertag System 2PK
Lazer tag deluxe 2 player system
The screen does not work properly. It is all jumbled up when it is turned on. It does not respond to any buttons being pushed.
    New Friend:
  • 3 Answers
Try new batteries and make sure to press the reset button with the batteries out and again when they are back in.
Posted on Jun 07, 2016
Why Screen won't respond to any touch?
Ur touch pad is gone bad get it replaced
Apr 24, 2014 | T-Mobile Prepaid Prism II
Officejet pro 8500a premium power light on but touch screen is off and will not respond and the power button will not respond either
hi, Mr Justin Becker
i think its a power supply problem, first you should try another dc adaptor, if your printer works fine with the new one, you have to replace it or take it for repair.
if it is a DC Adaptor problem it cost about: US $29.74
HP OfficeJet Pro 8500 AIO GSA printer power supply ac adapter cord...
Mar 06, 2014 | HP Office Equipment & Supplies
Unit doesn't turn on by pushing power button
Check the power supply make sure it's connected properly then if plugged to an outlet you know works and it still has no power then I'd say the power supply is bad
Feb 20, 2014 | Uniden Guardian Wireless Video...
Nerf gun lazer tag
i have the same problem and i noticed that when i go outdoor, the trigger will work again. i think it is something about interference by some sort of radiofrequenceis.
Nov 08, 2013 | Toys
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
My LGHD1209 the buttons aren't working properly, sometimes the power button responds when pushed but no others....
Try unplugging it and waiting 10 mins for any capacitors to discharge. Switch back on and retry buttons. If no go, control panel fault
Apr 28, 2012 | LG LWHD1209R Air Conditioner
Hello excactly on christmas day my sansa e250 stoped responding, it turns on but it does not move on to the home page of the player, the screen stays at the sandisk screen, then it fades for about 2...
Try to do a reset, follow these instructions if this does not work. Reseat the battery.
Resetting your player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Dec 25, 2010 | SanDisk Sansa e250 MP3 Player
AUDIOVOX CAR APS787N ADVANCED REMOTE START DOES NOT FUNCTION EVEN AFTER EVERYTHING IS CONNECTED PROPERLY.
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Oct 13, 2010 | APS787N Advanced Remote StartKeyless Entry...
Phillips Go Gear 2gb Jumbled Screen
The LCD controller is fried - call Philips and find out if you are eligible for an in-warranty replacement, b/c this is not a replaceable part.
Mar 13, 2009 | Philips SA3025/37 Flash MP3 Player
Hasbro Nerf Lazertag System 2PK Logo
208 people viewed this question
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
