Sc672 ricoh mpc 3000 - Office Equipment & Supplies
4 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh 1035
It says communication error to control panel at station.
Turn the copier off, wait 30 seconds, and turn it back on again.
It should go away. If it doesn't a technician needs to come out and look at the problem.
Posted on Jul 31, 2008
newport74
  • 58 Answers
SOURCE: sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Posted on Feb 26, 2010
  • 1833 Answers
SOURCE: I have a dsc224 or
according to your problem error code it means communication error to control panel at station.
And sc also means waste toner full. So first Turn the copier off, wait 30 seconds, and turn it back on again. It may not solve your problem then look in the back opposite the sorter or inside the machine there is a white plastic container, It may be full of toner.
If you find it full of toner then
first empty it out. If it doesn't solve your problem then Check the controller stall,controller board installed correctly with operation panel connectors. After that enter in the service menu and press the SP mode button,open the front door,turn off the copier,unplugged the machine.Wait 30 seconds again. then plugged the machine,close the front door and turn the copier on. Do the all job carefully and step by step. this may solve your problem.
Posted on Mar 16, 2011
My ricoh aficio MP3351 machine has a error problem SC672, plz kindly tell me what i can do???
SC672 occured when controller-to-operation panel communication error at startup After powering on the machine, the communication circuit between the controller and the operation panel is not opened, or communication with controller is interrupted after a normal startup.
.Controller stalled
.Controller board installed
incorrectly
.Controller board defective
.Operation panel connector
loose or defective
Make sure that the MBU is seated correctly. If not, SC672 occurs look at the picture to see what im talking about.
Sep 29, 2017 | Ricoh Office Equipment & Supplies
How to reset SC544 for Ricoh MPC 3000 when the keyboard is faulty
Maybe TOUCH panel doesn't work.
Try to calibrate it:
Yellow -->1-->9-->9-->3--> Press Stop(red one) 5 times.
1 - Touch screen adjustment!!! Follow instructions on the screen.
After calibrating exit and try again to enter service mode.
Good luck
Prepare to by new TOUCH Panel
Pifonski
Sep 30, 2015 | Ricoh Aficio Office Equipment & Supplies
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
Error code is sc672 on display ricoh mp2550n
change the bicu board and the problem will be solved
Good luck.
Apr 05, 2014 | Ricoh Aficio 1013F Copier
Ricoh 1232c sc 672
The correct way to get into service mode is to first press the Yellow "CLEAR" button then press the numbers 1 >0>7 then press and hold the Red "STOP" button.... Good Luck
Jun 08, 2012 | Ricoh Aficio 1232C Color Copier
Part Number for RICOH Aficio 1022
The fuser part number for a aficio MPC 3000 isB2374053 USA
and B2374054 for EU
Jun 01, 2009 | Ricoh Aficio AP2000 Laser Printer
Ricoh 1035
Jul 31, 2008 | Ricoh Aficio 1035 Copier
134 people viewed this question
k24674
jasbo
jasbo
