Question about Ricoh 6513 Copier
Where is the ID Sensor on the Aficio MP 20000LN2?
It is giving error code: 391
  • 87 Answers
SOURCE: aficio color 6513 id sensor location, td sensor location
toner density sensor is located in the developer unit. either the sensor is not reading cause something is covering it or it has poped so it can not reference any longer.
Posted on Oct 17, 2007
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
Ickoajnc
  • 183 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
  • 747 Answers
SOURCE: ricoh aficio 1515 with error code sc 392 and i
lets see if its a driver problem go to start go to devices printers now you should see your printer on the bottom half right click it the trouble shoot it the its going to ask you to fix then fix windows will take from there.
Posted on Feb 04, 2011
What is the error code sc400 in ricoh c2030 printer copiers
Ricoh Aficio MPC2030 Code: 400
Description
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400". The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than the value (default: 4.5V) specified with SP3324-005 or less than the value (default: 3.5V) specified with SP3324-006.
Causes
• Dirty or defective ID sensor • Defective ID sensor shutter
http://www.printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC2030&code=400
Sep 11, 2016 | Ricoh Office Equipment & Supplies
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
What is the error code 391?
This link may give you more incite on your error code problem
May 08, 2014 | Ricoh Aficio Mp 2000 Copy Machine
Error code SC 352
SC352
Error Code Explanation :
ID sensor, pattern edge detect error
The ID sensor pattern edge voltage is
detected to be not 2.5V twice
consecutively during an 800 ms
interval.
Posible Causes :
• ID sensor defective
• ID sensor connector defective
• Poor ID sensor connector connection
• I/O board (IOB) defective
• High voltage supply board defective
• Dirty ID sensor
• Defect at the ID sensor pattern
writing area of the drum
Sep 15, 2013 | Ricoh Aficio 1035 Copier
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
I have a ricoh aficio 450 and there is error code sc 350 - 01 apperes , what can i do ?
First of all never touch the optics section of a 450 will give you SC101
I got three solutions for you.
1. Clean the ID sensor.
Take out the Drum Unit, and locate it in the machine its on the top facing the drum.
2. Go to SP Mode. Clear Modes enter 1 0 7 press clear/stop for 4 seconds. enter 1, enter 3001-2 and execute, exit SP Mode.
3. Or Some developer is missing.
Nov 10, 2008 | Ricoh Aficio 450 Copier
The 391 code problem
SC 391 is image storage address error. Development BIAS leak. Charge AC output error.
Should be checked out by a technician. It could be a few things going on with it.
Sep 01, 2008 | Ricoh Aficio 450 Copier
Error SC 350 on Aficio AP4510
ID sensor defective
connection
defective
• ID sensor dirty
• Defect at ID sensor pattern writing
The problem is with your id sensor , it is sitting on the back side of the drum , in other words the further side of the drum when you slide it back in to the machine , these sensors get full of toner and gives this code , or the drum surface gets damaged and do not send the right patch to the system .you can whipe this sensor with a cloth .
Aug 10, 2008 | Office Equipment & Supplies
Ricoh 6513 Copier Logo
26 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
