Server Error in '/' Application. Value cannot be null. Parameter name: source Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.ArgumentNullException: Value cannot be null. Parameter name: source Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [ArgumentNullException: Value cannot be null. Parameter name: source] System.Linq.Enumerable.Where(IEnumerable`1 source, Func`2 predicate) +726 HH.Philips.Web.ProductRegistration.Classes.Validation.Attributes.ValidateSurveyAnswer.IsValid(Object value) +300 System.ComponentModel.DataAnnotations.ValidationAttribute.IsValid(Object value, ValidationContext validationContext) +174 System.ComponentModel.DataAnnotations.ValidationAttribute.GetValidationResult(Object value, ValidationContext validationContext) +39 System.Web.Mvc.d__1.MoveNext() +264 System.Web.Mvc.d__5.MoveNext() +1256 System.Web.Mvc.DefaultModelBinder.OnModelUpdated(ControllerContext controllerContext, ModelBindingContext bindingContext) +408 System.Web.Mvc.DefaultModelBinder.BindComplexModel(ControllerContext controllerContext, ModelBindingContext bindingContext) +1559 System.Web.Mvc.DefaultModelBinder.UpdateCollection(ControllerContext controllerContext, ModelBindingContext bindingContext, Type elementType) +607 System.Web.Mvc.DefaultModelBinder.BindComplexModel(ControllerContext controllerContext, ModelBindingContext bindingContext) +1539 System.Web.Mvc.DefaultModelBinder.GetPropertyValue(ControllerContext controllerContext, ModelBindingContext bindingContext, PropertyDescriptor propertyDescriptor, IModelBinder propertyBinder) +33 System.Web.Mvc.DefaultModelBinder.BindProperty(ControllerContext controllerContext, ModelBindingContext bindingContext, PropertyDescriptor propertyDescriptor) +543 System.Web.Mvc.DefaultModelBinder.BindProperties(ControllerContext controllerContext, ModelBindingContext bindingContext) +280 System.Web.Mvc.DefaultModelBinder.BindComplexElementalModel(ControllerContext controllerContext, ModelBindingContext bindingContext, Object model) +68 System.Web.Mvc.DefaultModelBinder.BindComplexModel(ControllerContext controllerContext, ModelBindingContext bindingContext) +1559 System.Web.Mvc.ControllerActionInvoker.GetParameterValue(ControllerContext controllerContext, ParameterDescriptor parameterDescriptor) +504 System.Web.Mvc.ControllerActionInvoker.GetParameterValues(ControllerContext controllerContext, ActionDescriptor actionDescriptor) +153 System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +692 System.Web.Mvc.Controller.ExecuteCore() +162 System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) +101 System.Web.Mvc.c__DisplayClassb.b__5() +66 System.Web.Mvc.Async.c__DisplayClass1.b__0() +15 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +1614 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +2705 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +1344
The 306 Error Code is generated when any corresponding process or operation could not be completed successfully by the application.
error 306 may prevent the user from performing the required action or may the application will close unconditionally.
Technical (Deep) Description of Error Code 306:
This is a full Description of ERROR 306:
ERROR 306: MCIERR_DEVICE_NOT_INSTALLED.This error is due to .The default facility code
ERROR 306: EVENT_APPMGMT_UPGRADE_COMPLETE.This error is due to Application %1 from policy %2 successfully upgraded application %3 from policy %4..The default facility code
ERROR 306: SQL_306_severity_16.This error is due to The text ntext and image data types cannot be compared or sorted except when using IS NULL or LIKE operator..The default facility code
ERROR 306: ERROR_SECURITY_STREAM_IS_INCONSISTENT.This error is due to The security stream for the given volume is in an inconsistent state. Please run CHKDSK on the volume..The default facility code
ERROR 306: CO_E_LOOKUPACCNAMEFAILED.This error is due to The system function LookupAccountName failed .The source of the error code is an RPC subsystem.
ERROR 306: STATUS_LOGON_SERVER_CONFLICT.This error is due to The Netlogon service cannot start because another Netlogon service running in the domain conflicts with the specified role. .The default facility code
Fixing Error 306 manually is a difficult process and it is not recommend unless you are an expert in this field.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
If you do not specify a Monitor control server, this parameter defaults to the value from the DB2DBDFT environment variable.
The default is DSN
Here is the trouble shooting site:
http://publib.boulder.ibm.com/infocenter/db2luw/v9r7/index.jsp?topic=/com.ibm.swg.im.iis.db.repl.monitor.doc/topics/iiyrcmonrasnmon0.html
Hope this was helpfull.
