Question about Garden
How to replace the clutch cable on a bolens 21a tiller
How to remove the clutch cable
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
KMusselmann
  • 247 Answers
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
Posted on Apr 17, 2009
SOURCE: BELT PLACMENT ON TROY BUILT TILLER MODEL
I am assuming your belt broke and you cannot find the replacement.
I had to go to an old timer that owns his independent business and he was able to find a much better belt than the one that came on the tiller. The Belt # is 1916657 and it is 25.5 inches long and 1/2 inches wide. It also has a kevelar core that will stand up to the constant gearing up and down.
Lowes was NO HELP AT ALL!!!!
Hope this at leasst get;s you in the right direction
Posted on Apr 25, 2009
  • 86 Answers
SOURCE: I have a Bolens 6.0
Has it sat with gas in it ? if so carburetor needs cleaned,The other thing could be water in gas look in tank for something that looks like a bubble floating in bottom of tank if you see one its water you remove tank clean out then if carburetor has bowl you must remove carburetor bowl clean out water.
Posted on May 13, 2009
emissionwiz
  • 76691 Answers
SOURCE: Troy bilt Bronco tiller Model#
Recheck the pulleys, sand the pulley grooves until they are rough for max grip w/80 grit and do a careful pulley alignment check with a straight edge, don't just eyeball it, then make sure the belts are not to loose, about 1/2" at center run of belt is good enough,
Posted on Oct 19, 2010
Bolens roto tiller
replace or adjust it
Jun 12, 2017 | Motorcycles
I have a bolen snow blower with a 208cc engine that runs for 5 minutes then quits seems to lose compresion
you may want to try and see if your cylinder walls are scratched when it loses compression try using som oil in the cylinder and see if the compression comes back up. if so then you may have a scratch cylinder. if compression does not come up then look at the valves to see if they are seating right. if not then you may have to do a valve job.
Jan 26, 2015 | Bolens 158 cc 24" Front-Tine Tiller CARB...
How do I remove the clutch
Remove the power unit, remove the plastic clutch/ starter cover, install a piston stop, with a t25 torx driver inserted down the center tube on the clutch drum remove the clutch drum, then using the proper clutch tool remove the clutch paying attention to the arrow stamped on the clutch- usually left handed thread. be sure not to lose small washer between clutch and drum.
Aug 31, 2014 | Yard Machines Cultivator 21A-121R900
" How to put belt on Bolens self propeled/ self muliching 21' push mower
should be some sort of tensioner device or spring that would need to be slacked off in order to facilitate removal try that
Jul 24, 2014 | Troy Bilt Tiller Bolens Swivel Post Pn...
On my tecumseh tiller the rope broke and the setup has rivets instead of screws is there another way to get it off without removing the rivets?
I'm guessing you have a 3.5 or 4HP 4 stroke with the recoil built into the top of the housing? If so, just remove the entire blower housing. It's only 4 bolts. You can then disassemble the recoil assembly to replace the rope.
Mar 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
I have a Bolens 6.0 OHV tiller M# 21A-332C163 and S# 1C283K40098. It will start on first pull but only run 2 or 3 mintues then quites. You then have to choke it to restart it then again it will only run...
May 04, 2009 | Garden
HELP WITH A HUSKEE TILLER #21A-340-131
The pdf manual can be found at mtdproducts.com. You need to know your model and serial number to access the download. Really not that good a manual.
Mar 23, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
