Question about Scott Cycling
Add brake fluid - Scott Cycling
2 Suggested Answers
  • 297 Answers
SOURCE: need to add brake fluid which reservoir do i add it to
Is normal because the brake pads/liners wear off ! As long you do not have a wet area by any wheel or at the master cylinder.
Posted on Aug 16, 2009
2005 chevy duramax 4x4 brake pedal goes all the way to the floor, ABS light on
You need to add BRAKE fluid. After that, blead your brakes. You need to find out where the brake fluid went. If there are no leaks, you need to check the remaining life on all four brake sets. If you have no leaks, chances are pretty good that you need new brakes.
Dec 14, 2012 | 2005 Chevrolet Silverado 2500HD 2WD
Not sure where to add brake fluid
LOOK UNDER THE HOOD LOOK FOR POWER BRAKE BOOSTER.ON FIREWALL ON DRIVER SIDE.YOU WILL SEE BRAKE MASTER CYLINDER BOLTED TO THE POWER BRAKE BOOSTER UNIT. POWER BRAKE BOOSTER LOOK LIKE A LARGE METAL BOWL.YOU WILL SEE BRAKE MASTER CYLINDER WITH A PLASTIC RESERVOIR WITH A COVER SAY BRAKE FLUID THATS WHERE YOU ADD YOUR BRAKE FLUID.
May 03, 2011 | 1996 Plymouth Grand Voyager
Where in the engine do i add brake fluid for suzuki wagon r
Brake fluid is always added to the brake master cylinder. The brake master cylinder is always located directly in front of the brake pedal in the engine compartment.
You should never have to add brake fluid. The brake hydraulic system is a sealed circuit and the fluid does not evaporate, nor does the brake fluid need replenishing due to "normal use". If you are having to add brake fluid to your master cylinder, there is a serious problem with your brakes that needs to be fixed.
Apr 04, 2011 | 1996 Suzuki Swift
In my 1999 Ford Escort, the brake light in the dash goes on and off all the time, but mostly stays on. I always check the E brake, but it is not the problem. The car drives as good as always so I'm not...
Check the brake fluid level in the master cylinder. If it is low, you need to find out why it is low. It could be that your brake pads are getting really thin and need to be replaced, or it could be a fluid leak somewhere else in the system.
NOTE: You should NEVER add brake fluid without investigating WHY the fluid level was low. You should never have to add brake fluid to your car.
Dec 26, 2010 | 1999 Ford Escort
Brake pedal travel long-slow to stop.
check your front brake pads and see if they need replaced then check your brake fluid after you change them. If you add brake fluid first you will leak brake fluid out when you compress the calipers to change the front brake pads. In the end make sure your brake master cylinder is full of dot 3 brake fluid before you drive.
Dec 11, 2010 | 1996 Ford Taurus
I need to add brake fluid. Does the car have to be warm or can I do it when it is cold?
You can add brake fluid when its cold just make sure you are adding the right fluid most vehicals take DOT 3 brake fluid, look inside your owners manual in the recommended fluids and lubricants section and make sure thats the right brake fluid for your ford......
Dec 07, 2010 | 2005 Ford Taurus
1994 Crown Victoria: need to add brake fluid to master cylinder...
Why would you add fluid?
As the front pads wear,the fluid will go down, not an issue
If you keep opening the fluid resevoir,you will let moisture in.
May 05, 2010 | 1994 Ford Crown Victoria
Can anyone add brake fluid to the truck? is there
There is nothing special to adding brake fluid. With the hood open on the drivers side on the firewall you should see the master cylinder. The cover is either a small round cap that will just spin off or a rectangular one that will pull off. Use DOT 3 fluid and fill. Make sure no dirt falls in.
Oct 27, 2009 | 1990 Toyota Pickup
The brake light comes on but doesn't stay on. Is this because the fluid is low? How do I add brake fluid? How do I know how much to add? Is there a special kind to buy? 1997 Avalon
Use a Dot 3 conventional fluid and add to a clear plastic reservoir you will find under hood directlty in front of the steering wheel.There is a float inside which will detect low fluid and trip the indicator.Big concern is why is the brake fluid low in the first place?This will almost always mean wearing brake pad linings as the fluid will displace the missing lining thats worn off the pads.This probably is an indication that near future brake repairs are on the way which will include brake pad replacement. The other sitation you may enounter is once the pads are replaced,you will then be in an overfilled situation to where the fluid will have to be removed to have the correct amount. I would probably get a visual inspection on the brake lining wear then elect to add fluid at that time or replace brake pads.
Jul 27, 2009 | 1997 Toyota Avalon
Cycling Logo
32 people viewed this question
Top Scott Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Scott Cycling Expert? Answer questions, earn points and help others
