Question about Proxim Tsunami.GX 32 (67706) Bridge
Default password router - Proxim Tsunami.GX 32 (67706) Bridge
99 s 10
Please reset your router and enter gain using the default username and password.
The default username and password for Netgear routers are admin and 1234 respectively.
1. Open your web browser and type in your router's IP address. The default IP address for Netgear routers is http://192.168.2.1.
2. Enter your username and password once prompted by your web browser. The default username and password for Netgear routers are admin and 1234 respectively.
3. Select "Set Password" from the left hand navigation menu on the router's manager menu.
4. Type in the old password, which should be 1234 if it is set to default and then type your new password twice.
5. Click "Apply" and the new password will take effect immediately.
Nov 05, 2013 | NetGear Computers & Internet
WRT310N
Hello I found the following info about the default settings on your router (you can reset your settings to the default ones by pressing the reset button on your router or the back of your router device):
Link is: http://pcsupport.about.com/od/linksys-default-passwords/a/wrt310n-default-password.htm
WRT310N Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Jan 28, 2012 | Linksys WRT Computers & Internet
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Belkin (F5D8231-4) Wireless Router...
New password wifi
Sep 07, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
How 2 put the password?
Sep 07, 2011 | SMC Barricade N Wireless Broadband Router...
My motorola router is unidentifying my username and password. How do I reset my Username and Password ?
For the motorola router's default username is "admin"; The router's default default password is "motorola".
If it is a Motorola-Cablerouter then default username is " cablecom"; The default password is "router".
Reset the router to Factory Defaults if the password is not working and re-configure it .
Nov 23, 2009 | Computers & Internet
I forgot my password
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Sep 08, 2009 | Linksys Wireless-G WRT54G Router
Where to find password to join wireless network?
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Cannot get password authorisation for netgear router
The default username and password for the Netgear DG834G router is:
username: admin
password: password
If that does not work (i.e., the default password has been changed), then the only way for you to log into the router is to restore the router back to its default factory settings. Then you will be able to use the default username and password above.
To restore the router's factory default settings, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
Apr 03, 2008 | NetGear DG834G Router
Computers & Internet Logo
78 people viewed this question
Top Proxim Computers & Internet Experts
Prashant M
Prashant M
kj henriksen
kj henriksen
Are you a Proxim Computer and Internet Expert? Answer questions, earn points and help others
