Question about Epson PowerLite 410W LCD Projector
Red will not show up
Every color except red shows up on the screen
Why doesn't it print red?
Could it be that the red ink has run out?
Mar 13, 2016 | Canon Pixma PRO-1 12-color large-format...
The colors are going out in Vizio E320VL. Can I fix this by replacing the main board or is there another solution?
Sounds like a faulty Timing Control board, I had the same problem except yellows showed up green.
Apr 03, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
The color is very dull with the exception of red everything has a red tint to it other than that the rest of the 50" screen is very dark. Watching t.v. or movies are out of the question the color is...
Thats a very common problem caused by bad CRT coolant which will need replacement to restore the set back to normal colors and brightness levels. You can get the CRT Coolant kit at www.tvrepairworld.com which fits your model. The kit contains the coolant for all three CRTs and the CD with instructions.
Jun 24, 2011 | Philips Magnavox 51MP392H Rear Projection...
My aiwa tv-- A219 is showing message AGING 19DCH in red color and nothing else except dispaly button is working.pls help me
my aiwa tv-- A219 is showing message AGING 2F01H in red color and nothing else except dispaly button is working.pls help me
Nov 11, 2010 | Aiwa F2000 20" TV
Screen is showing as blue color
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 14, 2010 | Dell E173FP 17" LCD Monitor
Red Color not working
Does this only show up in one connection IE: HD cable box, DVD player etc, If connected to a HD cable box a loss of red can mean a defective red component cable.
Aug 15, 2009 | Televison & Video
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Screen Spots
move your streo speakers or any thing w/magnet
Jul 06, 2008 | RCA F32650 32" TV
Epson PowerLite 410W LCD Projector Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
