Question about Dell Computers & Internet
Dell inspiron 3847
How do i add an internal hard drive
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
Dell has not published the procedures for installing an additional SATA hard drive, the Inspiron 3847 has a second 3.5" bay, for the second hard drive next to the primary hard drive, there should be a set of rails located in the bay, two 6-32X1/4, phillips head screws are needed, to attach the rails.
The procedures on pages 26 to 28 of the owners manual should give you an idea of what is required for the installation.
http://ftp.dell.com/Manuals/all-products-Infodev/esuprt_desktop/esuprt_inspiron_desktop/inspiron-3847-desktop_Owner%27s%20Manual_en-us.pdf
You will need a SATA data cable there should be a spare SATA power connector inside the case.
After installing the drive enter the system setup and check that the hard drive is 'enabled' [on] and recognized.
For Windows to recognize the second hard drive, it must be partitioned and formatted.
Go to Control Panel, Administrative Tools, Computer Management, Storage, Disk Management, right click new drive, select format, then you can assign a drive letter.
Posted on Nov 04, 2014
  • 7 Answers
SOURCE: Adding extra internal hard drive.
make sure you pc is turned off before you start. To add additional internal hard drive you will need to get SATA hard drive. when you open up your pc there will be a slot to put it in. on the new hard drive there will a display with shows you how to make that hard drive a slave. move the little thing to the right place and plug it in. when you restart it should read it .
Posted on Dec 16, 2008
rachelgeek23
  • 155 Answers
SOURCE: Trying to add another internal hard drive to Dell Dimension 3000
Leave the cable connection as it is. That is, one ribbon cable for the 2 dvd drives and the original cable for the old hard drive. You dont need to set the jumper on the second hdd. It has to be set to 'cable select'. Then make sure to connect the second hard drive to the middle port of the ide cable. Don't forget to connect the power connector to the drive. It should work that way.
Two ports on the motherboard
primary ide controller port (for master and slave hard drives. both drives jumpers should be set to cable select. then make sure to connect the right ends of the cable to the drive. middle port is for slave. port on the end is for master. check the power connectors for both drives.)
secondary ide controller port (for 2 dvd drives.)
Posted on Jan 24, 2009
  • 50 Answers
SOURCE: Dell inspiron 1300 won't reboot. HELP!!!
Your Hard Drive may have failed. to be sure. enter setup (F2) then run the hard drive diagnostic utility. a scan can take up to an hour or more and will tell you if your hard drive has failed. if it has you will need to replace it and reinstall your operating system
Posted on Apr 21, 2009
SOURCE: Hard Drive Upgrade
Yes, the motherboard should support that size drive with no problems. You will have to reinstall windows using the discs that dell sent you originally. Be aware the drivers for dell can be tricky to reinstall.
Posted on Oct 29, 2009
  • 3 Answers
SOURCE: how do I open the case to add hard drive on dell sx270
Go here:
http://support.dell.com/support/edocs/systems/opsx270/en/ug/cvrop.htm#1136140
Posted on Apr 22, 2010
How do I connect my dell inspiron 3847 running windows 10 to my tv
Wayne Vernon,
Since you do not mention the tv you are connecting to I cannot be sure about it. With that said you may need to go into the TV Controls and set the TV to HDMI 1 OR 2 and then see if that will correct itself.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 05, 2016 | Dell Inspiron 3847
I'm trying to increase hard disk space on a Dell
Hi.
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Regards.
Jan 01, 2013 | Computers & Internet
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Aug 04, 2010 | Dell Inspiron 1525 Notebook
Adding Sata drive to a Dell Inspiron 537ST
Yes you can use a PCI to SATA connector , check this link for the sample of that device that you can use for your computer to add additional SATA connections.
http://www.usb-ware.com/2-port-sata-pci-card-internal.htm
May 25, 2010 | Dell Inspiron 537 ST PC Desktop
My laptop is saying that it cant find the internal disk hard drive and that i would have to reseat it?i have a Dell Inspiron 1521..where do I find the internal hard disk drive on my laptop?
Internal disk drive..will be drive c:\...make sure nothing is loose on your laptop. if not. Go to control panel. Click ADD HARDWARE....and see if everything is enabled
Jan 31, 2010 | Dell Inspiron 1521 Laptop
I have just rep[laced my hard drive on my laptop (dell inspiron 6000) and have a no boot sector on internal hard drive / no bootable devices on the screen. what do i do next to fix this?
You need to run your installation/restore CD/DVD that came with the Dell. If you do not have them, you can order them from Dell for a nominal amount.
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Can i replace internal hard drive with 320 scorpio in dell 6400
hi welcome to fixya!
yes you can use 320 hdd scorpio as your internal drive for replacement to the older hdd drive of your dell 6400
Apr 14, 2009 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
538 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
