How to hook up with new converter boxes
I have a Mitsubishi HD 1080 which is hooked up to a DVD player, an indoor antenna and the converter box. What is the best way to hook up the system so the TV will play properly?
  • Steve Yocum May 11, 2010
    What is the Model # and age of set. Do you have HDMI inputs on set or only a HDTV IN Componet input.
    Sniper:
  • 105 Answers
This TV has a Digital Tuner built in?
Unless you have some purpose I would use the internal tuner.
Anyway. Use the HDMI input to hook up the Converter and Component (Red, Green and Blue video) to connect the DVD. You can use component for the Converter as well since it is reasonably comparable to HDMI (HDMI is 1080P Component is 1080i but it is difficult/impossible to notice unles picture is 60 or larger)
Posted on Jun 23, 2009
Mitsubishi TV WS-55909 only has 1 HD component imput spot; I have 2 HD devices?
look on the internet for a hub like usb ones the computers use.
Nov 29, 2012 | Televison & Video
Can't get hooked up so it ALL works vcr, converter box, dvd...
If the DVD works through this "box". Things are looking alright. There must be a number of inpus or hookups to connect VCRs or DVDs or what ever to this "box" that then allow you to hook tp the TV.
If this is the case there has to be a way to swithc the box to the different things hooked to this box so that you can see& hear them.
I do not know what this box is, but can only guess you need to get the manual or more info on how it works.
If you can try to hook each one of your pieces seperately to the box.
First unhook the DVD that works, and hook the VCR. If works, unhook the VCR and hook up the the enxt piece. That way you'll know if each of them is working.
Dec 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Converter box
3/23/09 --- I don't understand why you would hook your converter box or antenna to your DVD Player. Converter box is only functional between an antenna and a vcr (and/or a TV). DVD Player hooks directly to TV (NOT thru a vcr, coding on dvd discs will screww up the signal and make it fade!) Good luck.
Mar 20, 2009 | Insignia Digital-to-Analog Converter for...
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
Hooking up a convertor , when i have a vcr, dvd player
You can hook it up through the antennae system. Keep your dvr connected to the tv the way you had it. Hook up your TV rabbit ears antennae to the converter box in the connection on the left side of the box. Then hook up the antennae lead from the converter box to your TV on the right side connector. The only thing I'm wondering is, do you get stereo sound this way and does anyone know how to get it without hooking up the separate audio and video plugs? There aren't enough connections on the tv to hook up both sets.
Nov 12, 2008 | Zenith C27A24T 27" TV
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Digital converter box hook up
Can you describe how the DVD and VCR were connected prior to the converter box when they were working? I need to know that in order to guide you properly.
Thanks,
Dan
Jul 24, 2008 | Philips Magnavox 20MT133S 20" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
