Question about Archos Arnova 7 G2
Why won't my arnova 7g2 on button slides very loosely and won't turn on?
It worked properly the day before i read a book from it locked it with the on off button and put it away the next day when i came to unlock it the button was very loose just slides no matter how i try to hold it for it to unlock nothing is working now i did not charge it and it can no longer come on. I have very important information on it souvenirs that i would like to have. Thank you in advance for the rapid response
3 Suggested Answers
SOURCE: After i put in the
back up arnova and reflash the firmware. that solved it for me. still the wireless is fickle. sometimes, I tell it to forget network and then refind it. and sometimes it doesn't and I have to manually add it. My hunch is this model may have wireless issues.
Posted on Aug 06, 2011
TechyDrood
  • 2072 Answers
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Posted on Oct 16, 2011
My Arnova 10b g3 tablet won't turn on at all. What could be the problem.
If it is fully charged you need to hold the on button at same time as up volume to reset it..If that doesn't work .It will need a new battrey
Nov 29, 2014 | ARNOVA Tablets & eReaders
The lock on my kindle fire will not slide to open it.
You could try turning the device off and then on. Maybe also wipe your screen down.
Mar 23, 2014 | Amazon Kindle Fire HD
Cannot download yahoo messenger for arnova 90 3g
if you cant down load try combining it with other messagers like face book or google voice skype
Aug 23, 2013 | Archos ARNOVA 10 Android Tablet
Arnova 10 g3 won't turn on
i see that you are using a universal power adapter, do you have the voltage set to the proper voltage that the unit requires?
I have one of those radioshack universal power adapters.
Based on the fact that it says that it can charge via USB, you would need to have it set to 5 volts. if you have it set to anything different, you are risking damaging the unit.
Try a different power adapter as an alternate step. If that doesnt work, come back and I will try to help you further.
Feb 27, 2013 | Tablets & eReaders
How to put arnova 7 g3 in recovery mode
make sure the tablet is off, then push and hold the reset button(small hole on same side as power button), while holding the reset down push and hold the power button. continue holding both buttons until you see the "Arnova" flash screen, then release the two buttons. this should put you in recovery/download mode... it is not touch enabled though, and there are no physical buttons on the tablet, so you will most likely need the Rockchip flashing tool. Good luck
Jan 19, 2013 | Archos ARNOVA 7b G3
White screen won't turn off or close
Try pressing the power button and tapping the screen at the same time. Otherwise wait for battery to die and it should be ok when recharged.
Dec 26, 2012 | Archos ARNOVA 10 Android Tablet
I have arnova 7g3 and im locked out of it can you please help
I have an Arnova 7g3 and ive forgotten my password how do i sort this?
Sep 24, 2012 | ARNOVA Tablets & eReaders
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Brand new archos arnova 10 tablet. It is stuck on the charging screen. Won't turn on or off. Have hit the reset button. Didn't help, continues the same problem?
Oct 16, 2011 | Archos ARNOVA 10 Android Tablet
After i put in the wep key to my wireless internet it turnes off. I have the Arhcos Arnova 10 4gb tablet. Then it restart and only the name ARNOVA disappear in the screen. About a few seconds it blinks...
Jun 25, 2011 | Archos Arnova 10 4GB 4)
Archos Arnova 7 G2 Logo
41 people viewed this question
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
