Question about Ramonol Advanced Premium White Grease 150g Tube
Can you use ramonolwhite grease in a vintage motorcycle gearbox
    New Friend:
  • 104 Answers
Most gear boxes do not use grease. Gear oil which is moved over the gears as they rotate reduce the wear on both the bearings and the gears themselves. If this "grease" is not liquid I would not try to use it in a gear box.
Posted on Sep 09, 2014
What kind of lube goes in gear box on a 2005 honda cr85r
If you have a 2 stroke engine this requires SAE 80W/85W gearbox oil about .55 liters. If yours is a 4 stroker then 10W40 lubes the whole engine and gearbox. You can get a user manual online easily for this bike at owners.honda.com
Sep 13, 2014 | Motorcycles
Where are the Grease fittings for 1994 flstc
Not my vintage but probably only one on steering head right side.
Apr 23, 2014 | Harley Davidson FLSTC - FLSTCI Heritage...
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
Oil leaking from bottom of gearbox
if a manual gearbox ,then its fairly easy to repair without stripping box and thats to pump a grease gun full of LM grease into gearbox as the grease will settle in the bottom of the box stopping the oil leak but a auto box will require looking at
Mar 12, 2011 | Volkswagen Golf Cars & Trucks
Drivers side door window motor works window does not go down or up
It will be either a problem at the window regulator (the mechanism to which the glass attaches and raises/lowers it) or the gearbox attached to the motor.
This vintage had an issue with destroying three little nylon balls inside the motor gearbox that work against cam lugs. (Working from memory here & going back several years). I used to replace these by making my own pin-type rollers. I cut short pieces out of bolts, carefully measured to length, filed the edges and inserted in place of the nylon pieces along with a small amount of grease to provide lube. By doing this I was able to repair instead of replace the window motor. I THINK (but can't remember for certain) that I've seen these replacement rollers on the "Help" center misc. blister-pack section in almost all auto parts stores. Not sure if I have available an illustrated graphic of this gearbox or not. I can look if necessary. If you're not comfortable with or properly equipped for making your own parts for repair - then you'll likely have to replace the window motor.
Jun 25, 2010 | 1990 Ford F150
Suzuki bandit sticky gearbox
Stop riding the bike until you change the gearbox oil and oil filter. Yes, the oil is probably the problem. I am somewhat surprised that the pistons haven't seized yet. On the bottom or lower side of the gear box there will be an oil drain plug. Drain the oil and put in new oil. The oil fill hole is probably on the right side cover near the rear of the casing. The plug will probably have a dip stick to measure the oil level. Put in 10w40 motor oil. Ride the bike for a few hours then drain the oil to help flush out the dirt and grit built up in the gearbox. Put in fresh oil and a new oil filter if the bike has a filter.
Your bike is 18 years old and parts can be difficult to find. Your bike probably has an oil filter. If so, it desperately needs a new one. Google " vintage suzuki motorcycle parts " . I can not find a free service manual online. You may be able to buy one at www.repairmanuals.com
May 20, 2009 | 1993 Suzuki GSF 250 Bandit
Exsessive grease coming from chain sprocket area
If the grease is really thick and you don't lube the chain with that type of grease, then it would have to be from the swing arm being over-greased. If the grease is liquid then it would be coming from the output shaft seal. Get a new seal then remove the sprocket and clean the output shaft. Now remove the old seal and install the new seal.
By the way, if the oil in the gearbox looks like grease then it is past time for an oil and filter change. 10w40 motor oil.
Please rate this solution. Thanks!
Apr 19, 2009 | Aprilia Tuono 1000 R Motorcycles
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
May 02, 2008 | Kenwood KM300 Chef Stand Mixer
Ramonol Advanced Premium White Grease 150g Tube Logo
Top Gruebb Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Gruebb Vehicle Part and Accessory Expert? Answer questions, earn points and help others
