Question about Vehicle Parts & Accessories
Rear remove seats can I remove rear seat bottom from my 2013 nissan qashqui visia
    Sergeant:
    Champion:
  • 248 Answers
Never heard of it
Posted on Sep 11, 2014
How do i remove the rear bottom seat on my 2013 malibu LTZ?
You push in very ******* the bottom lip near the outer end of both sides to free the two spring retainers and then lift up..
Feb 28, 2017 | Seat Cars & Trucks
How do I Bend forward the back of the rear seats of a Nissan Pulsar 2014 to put the seat covers on?
Do not bend the rear seat back rests, they will never be the same again. On most (if not all) cars the rear backrests are bolted on by means of two bolts behind the seat, so first remove the seat (the bottom padding that keeps your backside from hitting the floor) by pulling the seat up. On some vehicles, the seat is bolted down with two 6mm bolts on either side. Once you have the seat out, you should see two bolts holding the back rest to the body of the car. Undo these, and the backrest comes off easily.
Now fit the seat covers and bolt the backrest back into place. It is not a difficult job, shouldn't take more than an hour or less.
Dec 14, 2014 | Nissan Cars & Trucks
How to remove bottom section of rear seat in 2010 Nissan Navara D40 ST Dual Cab to fit saet cover
there should be a couple of bolts one on each side on the floor in front of the seat bottom remove and get in car put your hands down between the top and bottom seats and lift hard
Feb 26, 2011 | Nissan Titan Cars & Trucks
How do i take the back off on a 1999 nissan maxima bucket seat
Hi, follow the instruction below......
Rear
See Figures 3, 4, 5 and 6
  1. Remove the lower seat cushion by pulling straight up on the front portion and disengaging the clips. Then hinge the seat upward to release the rear clips.
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
  1. Remove upper rear seat back-to-chassis bolts.
Fig. 4: Remove the bolts behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
  1. Remove rear seat back by tilting forward and pulling straight up.
To install:
  1. Install the lower seat cushion and torque the lower rear seat-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm).
  2. Install the upper rear seat back cushion and torque the upper rear seat back-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm)
Jan 19, 2011 | 1999 Nissan Maxima
How too remove back seat in a 1995 Nissan Maxima
Rear
To install:
Hope help with this (remember rated this).
Jul 19, 2010 | 1995 Nissan Maxima
How do I remove the back seat of my 1991 Nissan Stanza to access the fuel pump? Autozone says to remove rear seat cushion mounting bolts but how do you get to them?
I replaced my rear speakers I had to remove the entire rear seat bottom and top as for the bottom just pull up theres nothing holding it down just a few body clips like the ones that hold the door panels in place
Mar 18, 2010 | 1991 Nissan Stanza
Trunk won't open
you have to remove the bottom part of the seat and then un bolt the upper part
Mar 15, 2010 | 2005 Nissan Sentra
On a 1989 nissan maxima with sonar suspension II how do you disassemble the strut assembly? the mounting bracket for sonar adapters is in the way of the strut center bolt.
First you must remove the rear seat to gain access to the top strut mounts. The bottom of the rear seat comes out first. On the 91 model there are two tabs at the base of the seat bottm that you pull forward to release the seat bottom. I'm not sure if the 89 is the same. After removal of the rear seat bottom, you will see a bolt at the bottom of each side of the rear seat back that need to be removed. Fold down the arm rest and disconnect the vinyl cover at the base of the armrest to expose and remove two screws. Push up on the rear seat back to unhook three plastic hooks (center and one at each end) at the top of the rear seat back. Remove the seat back. Remove the large metal support panel that is behind the seat back. Safely jack up the rear of the car and support on jack stands so the rear wheels hang free. Doing one strut at a time, remove the two top strut mount bolts leaving the center strut stud nut in place. The strut and mount will lower out of the unibody. Disconnect the bottom strut mount. Remove the strut/coil spring assembly. Using a strut/spring compressor (some auto parts stores rent these) compress the spring. Carefully remove the top strut stud retaining nut, top strut mount, bumpers and strut boot. Carefully install compressed spring, strut boot, bumpers and top strut mount on new strut and install washer and retaining nut. Reinstall strut and etc. in reverse order.
Sep 15, 2009 | 1989 Nissan Maxima
Were is the fuel pump located?
The fuel pump IS located in the fuel tank. It is easily accessed in this particuar model, under the rear seat. If you have an arm reat in the middle of the rear seat, you'll need to go in through the trunk. Remove the cover from the the far back, between the back of the rear seat and the trunk space. Remove approximately 4 to 6 screws in the center piece of cardboard that attaches the armrest and rearseat to the cross menber of seperating trunk from seat.
From the back seat, grab the top of the back rest of rear seat, PULL HARD forward on left and right sides . This should disconnect the top. Then, on left + right-sides, toward the lower cushon, there will be a bolt, remove them.
Then pull up the bottom cushion.
In the middle of the floor you have left, where the bottom cushion once was, you will find the top of the fuel pump access. From the top there is a cable that goes toward the driverside, follow it to the connector which should be cover by a small piece of foam. Remember to diconnect the pump before attempting to service or replace it.
May 09, 2009 | 1992 Nissan Maxima
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
