Question about LG 42LH30 42 in. LCD TV
What is the problem that left half of screen is black
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
My sony Bravia kdl-46v5500 screen has colored lines on the left side then half the screen flicks black then the same left half side of the screen stays black then will go back to normal and then go...
These sets use for the most part two boards--each drives the screen on one side---also possible as suggested here the problem is inside the panel or where it connects to these boards--if inside the panel (the entire front screen unit) it is fatal as it cannot be got at and the display costs more than the set did new.
Oct 29, 2012 | Sony BRAVIA KDL46V5500 46 in TV
Half screen on sylvania tv is black (or white)
There are some defects in the board inside and should only be handled by a qualified service technician.
Aug 16, 2012 | Sylvania LC320SL8 Television
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Screen half black
either the screen has gone or been damaged or check the screen cable isn't loose or replace this first its cheaper than the screen go to eBay type n the make and model of your lappy and screen cable
Feb 11, 2012 | Toshiba Satellite P105-S6064 Notebook
Plasma only showing half picture
This is beyond consumer ability to repair. Please have it looked at by a qualified electronics service company.
Nov 23, 2009 | Panasonic Televison & Video
Have the screen is black. There a a few thin blue
Which half? top or is it a left or right half?
Depends on which but could be the main and either the x-sus or y-sus boards
Aug 21, 2009 | LG 50PG25 50 in. Plasma HDTV
My screen Half Black - Half Red
you have a warranty! the set has a problem either with the panel or the main board take it back to the store where you bought it and exchange it or have it repaired by a factory authorized repair place.
Mar 02, 2008 | LG 32LC7D Television
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
LG 42LH30 42 in. LCD TV Logo
Computer Repairing
Computer Repairing
