Brocade fsw 624 FACTORY DEFAULTS - Computers & Internet
4 Suggested Answers
De Guyver
  • 123 Answers
SOURCE: factory default
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624. Note: If you do not remember your password, you will have to reset the router to factory defaults. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Posted on Feb 16, 2006
  • 35 Answers
SOURCE: d-link dl-624
Check on computer what ip address router is assigning computer.If not reset router it should set it back to factory defaults.
Posted on Aug 27, 2008
  • 53 Answers
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Feel free to get instant online router/wireless router support at http://www.vtechsquad.com/wireless-router-support/ to fix D-Link router/wireless router issues.
Posted on Oct 23, 2012
Silkworm 2050
Hello, do you need to reset it because you no longer have the password? Sorry about the question however that is one of the most common reasons for folks attempting to do a "factory restore". If it is for a lost password, then my next question would be what firmware version are you running? I'm guessing it is something like FOS v2.6.x. If that is the case then the bad news here is you will need to obtain the Password Recovery firmware from your switch support provider. I say bad news because given the age of the SW 2050, this is probably no longer possible. You might give Brocade Support a try at one of the numbers listed on the following page: http://www.brocade.com/services-support/international_telephone_numbers/index.page.
If you have another need for the factory reset, reply back with those details. There isn't a factory reset button but perhaps we can look at different commands to achieve what you need to clear.
May 08, 2014 | Brocade Communications Systems SilkWorm...
I can not log into my adtran 624 router. How do I reset password?
There should be a reset button on the back of the router take a small pin and push and hold for 30 sec that will set the router to factory defaults you will loose any settings you have on it and will have to reconfigure it I have included the manual
http://www.adtran.com/pub/Library/Manuals/Default/Total_Access_600_Series_System_Manual.pdf
Aug 23, 2011 | Adtran Total Access 624 Router
Forgot login & pwd
If all else fails and you cannot remember your login information use a toothpick ir a similarly small object and press the reset button, Usually located somwhere on the back of the unit, look for a small hole the reset button is usually not visible but is just inside the small hole, press and hold this reset for 10 seconds or more and it should reset to factory defaults including the login info then you can access the unit using the factory login info. usually USERNAME: admin PASSWORD: password
Hope this helps Good Luck!!!
Jun 10, 2011 | CP Technologies - FSW-0808TX - 8-Port...
We reset the d-link di-624 wireless router and now it will not let us sign back on without the username and password which we do not remember. how do i factory reset the router?
Hi, when you reset your router the password is reset to default, and that default is admin admin. And to reset it, at the rear is a small hole in the hole is a button, remove from the power, and depress the button for a few seconds, then connect the power and try to logon again with your browser using the default settings.
It is also all explained in your user manual link below...
http://www.retrevo.com/support/D-link-DI-624-Wireless-Routers-manual/id/420ci368/t/2/
Aug 18, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Reset the IBM 2109-F16 SAN switch to factory settings
Were you able to find an answer to this? I have the same issue...
Oct 17, 2007 | Computers & Internet
WAN settings
The WAN settings should be configured by Verizon personnel only. If you reset the VDI-604 or VDI-624 to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
Factory default
Factory default
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
