Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Picture will freeze occasionally for approximately 30 seconds, then return to normal. Switching channels seems to take care of the freezing right away. It is a 53 inch rear projection about 8 years old, with no previous history of any problems.
  • 55 Answers
Good Day,
Try upgrading the Screen refresh rate.Right click on your desktop,properties,in the tab settings select advanced and then select the monitor tab.Select 85-100Hz in refresh rate.
I hope this helps...
Good Luck!
Posted on Jun 22, 2009
TV won't respond to remote or button on the TV
Make sure you are running the Keygen as administrator
Jan 28, 2014 | Toshiba 55UL610U 3D TV
I have a LG PC1DV Plazma and every now and then the picture will freeze, the sound continues on and you cannot change channels. the only way to un freeze is to turn off tv wait 30 sec then turn back on and...
Contact your LG dealer & have someone call to check the software version currently used by the TV. It may need updated as there is an issue for picture freeze, if this is ok there could be a problem with the signal strength of your signal, if this drops then it will also cause the picture to freeze, in which case you would need to have your aerial checked.
Dec 21, 2009 | LG Televison & Video
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Dec 05, 2008 | LG 32LG40 32 in. LCD HDTV
My EPG on my Goodmans GTVL26W28HDF no longer works
You may be right but if you leave it in standby overnight it should recover.
Jun 14, 2017 | Televison & Video
Picture freezes and no sound or sound and pictures normal
Okay,only one thing you could check,and that would be your electrical outlet.Using another outlet from a different room(power extension cord) to plug your TV and see if it does the same thing.
If it does,don't bother,you need a repair serviceman to take care of it or if it is under warranty,call your retailer!
solutiondoct
Nov 11, 2008 | Samsung HL-R6167W 61" HDTV
My Humax PVR picture freezes after a few seconds (on BBC1) and no controls work - switching off and on the problem recurs.
Fixed it. Unplug your aerial, start it up (it will not freeze), go into the menu and reset to factory defaults (code 0000). When it has finished plug in the aerial but stop it searching for channels, reset to defualt again. Next let it find the channels and save them and it should work fine (mine does).
Jul 03, 2008 | Televison & Video
Issue was with the HD channels only.
Updated the firmware of the TV to ver 2.
Now the TV will stutter for a second when changing to a HD channel but it no longer locks up.
Feb 15, 2008 | Westinghouse SK-26H590D Television
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
