Question about Famous Brand F1703 Monitor
It won't turn on.
I got the monitor from a thrift shop. It had no power plugs or a VGA cable.
I found a estimated 35 volt power plug that worked in the audio hole.
It worked for about 2 months.
Now when I plug it in, the blue light on the power button blinks twice. then nothing.
It won't respond when I press the power button, It won't do anything at all.
I dunno, since it was free and came with no papers I'll give up.
It was a really awesome monitor though.
    President:
  • 3,085 Answers
The inverter has failed.
Posted on Jun 22, 2009
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Jun 13, 2014 | Acer 22" X223w LCD Monitor
I've got a Scanport H21 monitor that the green light comes on but has a black screen. Can not dring up a menu or "VGA IN" message.
You can try a different cable for VGA. Check if the port is lose. The green light is only indicating a proper power supply to the monitor. The display is very much dependent on the VGA cable. If your monitor also has HDMI port, you can try to connect using that cable (provided the display adaptor also has HDMI port). If nothing works for you, take it to a hardware engineer or local repair shop.
Jan 20, 2014 | Scanport H21 21" LCD Display Monitor
Compaq laptop prasario cq60 won't turn on yes it's plugged in yes outlet works yes I checked all electrical connections and outlets
have you tried to remove the battery and wait a couple of minutes then re-insert. make sure your battery charger is working, light flashes also indicates low power.
Mar 01, 2013 | Computers & Internet
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
No pitcure, but the power light is on
My first bet is on a dead power-inverter. Get it replaced if you can still see a very darkened picture. OR... if there's no picture at all, call warranty support or take it to a repair shop. Also, if you're fine with electronics, I can guide you step-by-step to diagnose the fault.
Mar 06, 2011 | Samsung SyncMaster 910MP 19" LCD Monitor
I moved and lost the video cable to my HP Pavilion F1903 monitor where can I get a new one
Any "male-male" video-cable will work.
Check whether you need a VGA-to-VGA cable, or a DVI-to-DVI cable, depending on the connectors (oval for VGA, rectangular for DVI) on both your monitor and your computer's video-card.
Try the local "Thrift Shop" (Salvation Army, Value Village, et cetera).
Try any local computer-store.
Try any "big-box" store (BestBuy, Walmart, Staples, OfficeDepot, FutureShop).
Try 'www.ebay.ca'.
Nov 18, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Gateway Monitor Power Supply Problem
I have the same problem. I just unplug it and reconnect. The display comes back. I have no idea why this is happening.
H
Jun 25, 2009 | Computers & Internet
Westinghouse LCM-19V7 powers on, but picture only stays for a sec
It's probably bad capacitors on the power supply board. These monitors are notorious for having the electrolytic capacitors blow out; cheap components! I would suggest replacing the two 1000 mfd capacitors and the three 220 mfd capacitors with 35 volt components from Radio Shack. That fixed one of my LCM-19V7s but not a second one which seems to have some other power supply problem.
Mar 24, 2009 | Westinghouse Computers & Internet
Brother monitor
yes it is an old monitor using most 486 cpu.
Mar 07, 2008 | Gateway FPD2275W LCD Monitor
Sceptre X7G nagaVI problem
For most of the problems above you will find it is bad capacitors on the power board sending unstable power accross to the controller board.
For the last posted problem (Comment by Guest, posted on Jan 02, 2008) you have a dodgy inverter circuit that needs to be repaired.
Both faults should be fairly cheap to have taken care of at your local TV repair shop. You may need to call a few in your area not just for a quote, but also to see if they are willing to work on an LCD monitor.
Hope that helps you all =)
Dec 21, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Famous Brand F1703 Monitor Logo
142 people viewed this question
Top Famous Brand Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Famous Brand Computer and Internet Expert? Answer questions, earn points and help others
