Question about Seiko Melodies in Motion Clock
Why does my Seiko only play the intro to a melody?
Why will my clockl no longer play song or move
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling
UsedClockParts.com
Sep 02, 2014 | Seiko Melodies in Motion Clock
Seiko wall clockNeed battery cover and repairs Model #QXM139SRH
I sent my clock off to Seiko for repair, useless, they said it was in the circuitry. I had them send my clock back. I ordered a new gear box $2.00, replaced that, it will work as long as it's flat. If you look you can see how the clock cycles I made sure it was "locked" in (you can hand force it) then I removed one of the gears so it doesn't cycle down but stays in the up position at all times. Music plays, lights go, just no motion now. Call Seiko for replacement battery cover.
Jun 22, 2014 | Seiko Melodies in Motion Clock
When my melodies in motion clock plays the music (Beatles), it sounds distorted.
You may have a loose speaker wire connection or the speaker could be bad.
Dec 09, 2013 | Seiko Melodies in Motion Clock
I need to know how to set a Seiko Melody in Motion clock that I just purchased at a resale shop. It is working but the time is wrong. It is oblong with 4 clowns at the bottom. Thank you.
i had that clock hre. and all the insides are special from seiko, i would send it to them. the movement is encased in plastic and some lever rods attached to them . may be worth sending
Jun 17, 2011 | Seiko Melodies in Motion Clock
My seiko musical wall clock doesn't play music anymore
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
Feb 23, 2011 | Seiko Melodies in Motion Clock
Seiko Melodies in Motion Clock Logo
413 people viewed this question
Top Seiko Home Experts
k24674
Jimmy Accardi
Are you a Seiko Home Expert? Answer questions, earn points and help others
