Question about ASUS F3Jc Notebook
My asus F3j wont boot up all i get is an error message recovery not finish please try again ?
5 Suggested Answers
IainMSB
  • 10 Answers
SOURCE: ASUS F3J DVD drive problem
LG and Samsung both make good drives - otherwise they would probably not be in business in the competitive market they are in. However, it would not be certain which one was "good" for your laptop.
The ASUS F3J series laptops all seem to share the same optical drive characteristics.
If you have established via system diagnostics that the DVD is faulty and needs replacing, then I recommended best practice would be to replace it with the standard DVD drive replacement part from ASUS. If your warranty is still valid, then you could have it replaced it under warranty.
It is "best practice" to use an ASUS part, because, if you do not, then you may have problems:
(a) problems installing the non-standard replacement part into the laptop housing (i.e., it just won't fit in, or, even if it does then it may not fit securely or neatly into the laptop housing).
(b) problems finding the correct Windows driver for the new hardware part (i.e., when Windows auto-detects the new hardware and tries to find a driver.)
The ASUS F3J series optical drives all seem to be spec'd as either:
DVD COMBO: 8X/ 24X24X24X (max.)
DVD Super Multi: 5X/8X/4X/8X/4X/24X/10X/24X/8X
So, you might consider the alternative of getting an external USB DVD which at least matches one or both of those specs. The USB drive will come with the appropriate drivers.
Hope this helps/is of use. :-)
Posted on Aug 22, 2009
popeye7608
  • 50 Answers
SOURCE: i am not able to boot my Asus EEEPc 1000h by the DVD
that's right. You can use external DVDRW drive and you must enter your DVD driver (usually you get it after you buy eeepc) into external. Cause your DVD driver include driver for eeepc and recovery windows for your laptop, just in case, your laptop get some crash on several software and get into factory default setting.
Posted on Sep 19, 2009
  • 2973 Answers
SOURCE: i have a asus x53s laptop when i boot up
This is a pre-crash stage of Windows. Re-install Windows by following the link given below as a guideline:
Crashed Windows : No Problem
Posted on Jan 19, 2010
  • 4 Answers
SOURCE: a new asus eee pc 1005ha boot problem
replace hard drive,
First remove 4 bottom screws, and Ram cover.
remove keyboard by pressing down on the 4 tabs across the top of the keyboard with a small flathead screwdriver. disconnect ribbon from body
once keyboard is removed unscrew the 6 black screws where the keyboard was they are the same as the other 4 bottom so do not worry about mixing.
pop open the top casing starting in the top right working your way around to the top left in a clockwise motion.
remove and replace the harddrive from here.
Find a PC install a program such as WinToFlash (freeware) and create an installable copy of Windows XP on a flash drive no smaller then 2 gb.
Put flash in USB slot
press escape as computer starts choose the USB drive
Format and install XP from flash
Posted on Dec 09, 2010
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
Safeboot corrupted error 92h message
run the receovery again and wait for the process to finish before removing the cds.
Sep 26, 2012 | Toshiba Satellite M55-S325 Notebook
My asus f5rl keeps coming up with boot error 0xc000000f when turned on. How can i restore it please?
Before going any further, please help to confirm the following three points:
1. Does any other error message appear when starting the computer?
2. Did the computer start properly before?
3. Have any changes been made on the computer recently, such as an installation or upgrade?
The issue can be caused by many factors, such as incorrect BCD entries and incompatible hardware or software.
Based on the current situation, I suggest trying the following methods to troubleshoot the issue.
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ..." appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Can the computer be started now?
If the issue persists, I would like to confirm if System Restore was enabled before.
If so, we can try to restore the system to a state when your computer worked properly in WinRE.
Method 2: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Instert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Jan 16, 2011 | ASUS Computers & Internet
Bootmgr Missing
reinstall WinOS from Windows CD
Dec 17, 2010 | ASUS UL30A X7 1.3 GHz 320GB 13.3 inch...
My EEE PC1015 PE keeps giving error message "Reboot & Select proper boot device of Insert Boot Media in selected Boot device & Press a Key." Also, beeps continuously for approx. 1-2 min then stops...
in situations like this you just must download the correct manual and reinstall the OS,if you have no disk choose a different OS some are virtually cost-free
Aug 29, 2010 | ASUS Eee PC 1000H Laptop
Make sure the new drive is the same size as the old one (physically the same size) and that you swap out the front door as well as the back door screw connector so this way the drive fits in the slot properly.
Aug 22, 2009 | ASUS F3Jc-AP141C Notebook
Windows Error Recovery - ''an unexpected I/O error occured''
Hi
This seems to be serious problem. Please share the exact error message. If there are any external devices connected to the system please remove and then try to boot the system again.
Also post the brand and model of your laptop so that we can be more specific in terms of the steps.
Thank you
Rakesh
Dell Expert.
Jan 06, 2009 | Computers & Internet
NTLDR missing
I can get into the Boot First Screen but can't seem to change anything within it... These screens seems to be selectively responsive to my key presses.... I can get the bios screen up, boot order screen up but not necessarily do anything within them... e.g. I can't restart the pc using ctrl alt del when the missing NTLDR message appears.... also I have put an XP disc in and it says to press any key to BOOT from CD .... I Do so but obviously it doesn't recognise it so it gives me the missing NTLDR message again! :(
May 24, 2008 | Microsoft Windows XP Professional With...
Pc won't boot up
try hitting <F10> to change boot sequence, I think that CD isn't selected/available, and continues trying to boot from NO OS.
May 18, 2008 | ASUS A7V8X Motherboard
ASUS F3Jc Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
