Question about Signature Control System Signature 77516 Adapter for Connecting 8014 SoloRain to Hunter Valves
Does sprinkler system need to be turned off to install the signature 8014 valve actuator
  • 41 Answers
If it is actually spraying, yes. But if it isn't, no
Posted on Mar 05, 2015
Manual for 8300 system
Download the instructions from the website.
Jul 02, 2014 | Signature 8304 EZ Pro Jr. 4 Station...
Installed valve to water supply then added faucet bib thenthe sprinkler supply line water enters valve but no water out to sprinklers
You might have missed some constrictions. Try blowing out the zone with compressed air to make sure it's clear.
Jun 24, 2014 | Lawn Genie Male NPT, 3/4 In. Anti-Siphon,
Irrigation valve parts diagram
Most likely cause is small bit of contaminant (TFE tape, etc.) is caught in the seat area, or possibly (if electrically actuated) the solenoid is not working properly.
Jul 24, 2013 | CHAMPION IRRIGATION PD Champion Irrigation...
Nelson solorain 8014 manual
Buy a new timer. Sounds like the circuit board has a short. or call the manufacturer number should be in the instructions.
May 18, 2013 | Signature Control System Signature 77516...
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
Sprinkler system problem.
the bleeders or solenoids are probably open or loose on all the zone valves.close each of the bleeders and the water in each zone will stop.The zone valves are usually installed ad part of a manifold enclosed in a green box installed flush to the grade or grass. Pull the cover off to expose the zone valves
Apr 26, 2009 | Garden
Brass Champion Sprinkler Valve
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Jul 27, 2008 | Electrical Supplies
Signature Control System Signature 77516 Adapter for Connecting 8014 SoloRain to Hunter Valves Logo
446 people viewed this question
Top Signature Control System Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Signature Control System Garden Expert? Answer questions, earn points and help others
