Question about Tablets & eReaders
I bought a proscan tablet PLT7777g-q in January, it is stuck on the android screen now. I loved it, so disappointed!! Any suggestions?
5 Suggested Answers
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
newfie_todd
SOURCE: Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Posted on Apr 27, 2014
gopakumarg43
  • 75417 Answers
SOURCE: Proscan tablet Plt8235gbt-kbt is stuck on android
O/S corrupted. Contact the authorized service center. O/S might have to be re-installed.
Electro help
Posted on Jun 06, 2014
  • 74 Answers
SOURCE: My proscan tablet is frozen on android logo
You could use this tutorial to reset the tablet
What can I d to factory reset my pros can plt7777G tablet.
Hi Patricia,
You can perform a reset / hard reset to completely wipe out the Android phone this will also remove any passwords and configurations.
Note : To perform this process on your own risk
Step by step guide to reset proscan Android Tablet PLT7777G-Q
Step 1: First, turn off the tablet.
Step 2: Press and hold the power button and quickly poke the reset hole until you see an Android logo on screen.
Step 3: Use the paper clip to poke the hole to navigate until you go in to the Wipe data or Factory reset.
Step 4: Use the power button to select and you should be able to see the screen menu.
Step 5: Select the Delete all user data and restart and it will process it then select restart/reboot after the reset.
Once you have reset the device back to factory settings, all data will be deleted and cannot be recovered.
Or: you can also do this by going into the proscan Android Tablet PLT7777G-Q`s settings>backup and reset and selecting the factory data reset option.
Jan 15, 2015 | Tablets & eReaders
What do I do if my proscan PLT7777G-Q tablet won't
plug in the usb an power it up/down alternately till it asks to recover it take your time
Oct 19, 2014 | Tablets & eReaders
I have a proscan tablet plt7777g. It will not load it turns on and gets to part where it says android but it just stays there.
First Turn off the Tablet, and locate the small pin hole reset.
Press and Hold the Power button while poking the hidden reset button with a small object like a paper clip until you see the Android logo, let off the power button.
Use the paper clip and poke the hole to navigate the menu, hit the power button to accept the menu items.
First select Wipe Data if avialable, then Select Factory Data Reset. Reboot the tablet after it is done reinstalling Android.
This is a common problem with these off name tablets, be weary when buying cheap devices.
Oct 11, 2014 | Tablets & eReaders
Why wont my proscan android tablet turn on ?
If you haven't done so already, try holding the power button down for a long time (30 seconds+) when you switch it on. If no success, try again but hold down the power button *and* the volume-up button when you switch on.
Aug 10, 2014 | Proscan 7-Inch Android Internet Tablet,...
It crashes, won't turn on after resetting numerous times
Replace the battery delete apps you don't need and then reset
Jun 30, 2014 | Proscan 10.1-Inch Internet Tablet,...
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
What do you do when you forget your password on a proscan tablet
go to were you bought it immediately the will have some suggestion and some computer stuff.
Dec 30, 2013 | Proscan 7-Inch Android Internet Tablet,...
Proscan 7 inch tablet keeps freezing
My proscan tablet is keep freezing and lines are coming across the screen. What can I do
Dec 28, 2013 | Proscan 7-Inch Android Internet Tablet,...
Tablets & eReaders Logo
22 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
