Question about Konica Minolta Genuine Di650 Di551 Di5510 Di7210 Copier 604a Toner 8937-801
Sc28-03 minolta di 650 - Konica Minolta Genuine Di650 Di551 Di5510 Di7210 Copier 604a Toner 8937-801
  • Konica Minolta Master
  • 6,161 Answers
Pull out the middle assy. you will see a section that has a grill over it inside there are two/three very thin wires. They carry a very HV during the copy process not with the section out. There is a clean device on them that goes from one end to the other, your code deals with the motor that drive the cleaning device. Remove the assy., two screws front rear whole assy. comes out remove the tiny gear bring the cleaning device to the rear re-install gear re install assy. if the code comes back burn out motor, can also get a tech to turn it off for ever, not really that important.
Posted on Dec 30, 2015
WHEN TRYING TO CLEAR A PAPER JAM, I PRESSED DOWN LEVER A; BUT WHEN i TRIED TO PULL OUT THE UNIT, IT SEEMS LOCKED AND WILL NOT COME OUT?
Check the actuator if deform or sometimes a small torn off paper remains on it. Position the leve A down steady before pull.
Dec 02, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Why is amy copier throwing a sc 49-1 code?
What do you mean yo cleaned the control board?? Did you remove it????? IF you did major problem a Will have to go back and remove each connector looking for a bend pin and ensuring each connector is properly seated. Never remove board unless required. As for the code: please check code could not find in the service manual
May 22, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Error code 42-2
Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 19, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Di650 error code 42-2
FM-2 Fan code, Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site
No work machine code sc23-03
clean and inspect the drum cartridge replace the drum and the cleaning blade when was last time pm was done do be done ever 250,000 copies do one.
Mar 14, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
I have 650di minolta machine. now it the start code No sc36-02 emerged. please tell me the soloution
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem with the fuser (The Hot Part) the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Feb 14, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Sep 17, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
Sir i face problem in di 650,i place original
Sir,
Do you have the paper selection in AUTO? Mite you also check your defaults settings
Feb 20, 2010 | Minolta Office Equipment & Supplies
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
Konica Minolta Genuine Di650 Di551 Di5510 Di7210 Copier 604a Toner 8937-801 Logo
82 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
