Question about Samsung Refrigerators
Door display error code 8888 - Samsung Refrigerators
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: Error code E000732 8888
It means you should call a tech to come out and look at your machine
Posted on Jul 23, 2015
Frigidaire Gallery GLTF4920ES3 Front Load Washer keeps powering off and on during a cycle. The LED panel goes crazy when it's off, no error codes, just a horizontal then vertical line and random cycle...
To get a diagnostic code out of this take the screws off the lid. There should be a manual on this model. You have to hold start and cancel together with the machine off, but plugged in for 5 seconds on this model. If you had a long fill problem on this unit the machine clunks out and doesn't operate correctly. Refer to that tech sheet to see how to reset the error codes on the unit and try again. If your machine has 8888 display instead of just little led lights, the error codes are much easier to read and understand through the tech sheet. To put the unit into diagnostic mode, you have to set the dial all the way to the specified cycle setting and follow the instructions from there. It will throw only an error code if you hold Start and Cancel together.
May 19, 2014 | Frigidaire ATF6000ES Front Load Washer
Error :8888 in bajaj induction cooktop
Error code: 8888 on my new induction stove please what is the solution.
Nov 18, 2012 | Cooktops
i have irc5185i it show e000732-8888 pls help me
Oct 06, 2012 | Canon imageRUNNER C3200 Copier
Samsung microwave displays 8888 beeps then 6666
how can i fix this problem i have an air conditioner whit the same problem and don t work please help me here are very hot
Jun 20, 2012 | Microwave Ovens
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to ''turn switch off and on''. What could be wrong?
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
- E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
- E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable).
2. Turn ON the main power switch.
3. Change the setting values of the following service mode items.
- Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'.
- Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'.
Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1.
- Color Image Reader-E1: Platen cover model
- Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1)
- Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180)
4. Turn OFF the main power switch, and connect the DDI cable.
5. Turn the main power switch ON.
Note: How to turn OFF the main power switch.
When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine.
1. Hold down the control panel switch for 3 sec or more.
2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.)
3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
Nov 17, 2009 | Canon Office Equipment & Supplies
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to "turn switch off and on". What could be wrong?
Nov 17, 2009 | Canon ImageRunner 2220N Copier
What is the pairing code for a pama visor mounted
Hello Give this a go
Sunvisor range
PNG8......8888
PNG9......8888
PNG10....8888
PNG11....8888
All The Best Jon Bodley.
Sep 21, 2009 | Cell Phones
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
