SOURCE: Waste Toner Full/ Not Install
Behind the little container for the waste toner there is a sensor that senses whether the toner basket is full or not. If the sensor itself is dirty, it can give a false reading. First try cleaning out the area under the container to see if the switch works. Also make sure the container is clean, because the sensor works by sight, so if it looks full because it's dirty, it will give a false reading. I have heard of people disabling that sensor in various ways, but that can get dangerous to the printer. I can't recall the details on that exact model, but I believe there is a diagnostic of some sort that can test that sensor to make sure it works right to begin with.
SOURCE: how do I replace the
On the left side of the machine, where the pages come out, Behind the catch tray or finisher there is a small door that pulls open, it flips downward. Tilt it open, slide out the filled bottle and put in the empty on, One waste bottle comes with a box of toner.
SOURCE: WASTE TONER CONTAINER
The Counter for the Waste Toner has to be reset. You go into service mode by selecting Additional Function, then depress the 2 & 8 at the same time then the Additional function key once again. You should see a screen that says copier, feeder, etc. Touch " Copier " and then you should see a new menu across the top of the screen. Far right is " Counter ". Select it and then go to " MISC ", you should see Web, Waste toner, etc. Select Waste toner and select the " C ( clear ) " key and the counter should reset to all zero's.. Select the reset key a couple of times to get out of service mode. You may want to see what's all in service mode to get an idea of what's there. When replaceing time change items most likely there will be a counter to reset in the same way. Good Luck.
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
The drum ground circuit is defective, this allows excess charge to build up on the drum surface and "pull" developer material through the cleaning system. This circuit needs to be troubleshot and then replace developer material with fresh devo, then run AT (auto toner)
Also, would recomend cleaning out Drum Cleaning Unit, otherwise the drum will be scratched from devo against drum blade/drum.
