Question about VONNIC Computers & Internet
Password reset dvr - VONNIC Computers & Internet
How to reset my pass word on my Samsung Security Video System SDH-B74041
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
These reset procedures cover many Samsung Security DVRs, but not all. I will add reset procedures to this article as they become available to me. By design, Security DVRs are made to be secure, and not all of them can be reset by the consumer. If you have an urgent need related to your Samsung Security DVR, you should contact Samsung directly at their support page Samsung Support, or by calling: 877-349-3149. For less urgent matters, you can email them directly at Email Samsung Support. Support is available 7 days a week, 9:00 am - 9:00 pm EST.
Jan 08, 2017 | Samsung Home Security
How do i reset my dvr
If you stuck in CCTV DVR Password Reset process. just visit
CCTV & Networking Technical Support Channel on youtube.
Here is the link:-
CCTV Networking Technical Support
Jan 13, 2016 | Swann Communications Home Security
How do I reset the admin password in this dvr?
REMOVE THE ON BOARD BATTERY IN DVR FOR 10 SEC AND PUT AGAIN THAT GONNA RESET IT
Mar 19, 2015 | Home Security
Qihan dvr super password
Forget the DVR password, how to generate a new one with software ...
www.hkvstar.com/.../forget-the-dvr-password-how-to-generate-a-new-one-with-softw...
Nov 4, 2013 - If you forget the DVR password, you can use the password generation software to get a new super admin to unlock the DVR.
Reset DVR password to Factory default - • CCTV Forum
www.cctvforum.com/viewtopic.php?t=39460
Jan 26, 2014 - 15 posts - ‎4 authors
I have a DVR shown below and I am not able to reset the system to the factory default. It is an 8 ch standalone, unbranded, no make or model ...
How to - Zmodo DVR Resetting to Factory Defaults - YouTube
? 0:46
https://www.youtube.com/watch?v=rT-cUgWbHQM
Sep 24, 2009 - Uploaded by CCTVHotDeals
This video shows how to reset your DVR to factory defaults. ... Reset PasswordDVR H.264,AHD, With Super ...
CCTV H264 DVR password reset superpassword super password ...
https://dashcamtalk.com > Home > Forums > General Forum > Off Topic
Jan 2, 2015 - 12 posts - ‎7 authors
I was searching on internet for this problem because I set the password one year ago, I forget it and I want to reset the password. I have a ...
How to reset password ?
support.qube.asia/127247-How-to-reset-password-
STEP 2- Open the cover of the DVR. STEP 3- Remove the CMOS battery. STEP 4- Power On the DVR. STEP 5- Enter a password. Username: As given.
[PDF]Qihan NVR manual
www.riasztobolt.hu/pictures/down/en_tmanual_quihannvr.pdf
Support modifying the user's authority and password. Subdivide the authorities (preview, ... DVR: Digital Video Recorder. IPC: IP Camera. IP PTZ: Network High ...
Aug 13, 2014 | Home Security
Dvr password reset
see hte following link below. you need to set the DVR back to default in order to reset the password.
http://www.safe-n-secureinc.com/Support/Samsung/Samsung%20SHR-2160-2162-2080-2082-ENG.pdf
Nov 06, 2013 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung dvr 7162 need to reset password
please help me to reset password Samsung DVR SHR7162
Dec 24, 2012 | Samsung Shr-7162-15t Dvr Shr7162 Techwin...
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Computers & Internet Logo
44 people viewed this question
Top VONNIC Computers & Internet Experts
David Payne
David Payne
Are you a VONNIC Computer and Internet Expert? Answer questions, earn points and help others
