Question about Panasonic Microwave Ovens
Panasonic microwave oven nn-st557m/w water condensation underneath cabinet
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 23, 2009
  • 178 Answers
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Posted on Sep 14, 2009
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
heatman101
  • 43501 Answers
SOURCE: my panasonic microwave oven is not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfsghs
Posted on Sep 30, 2010
HOW DO I change the lamp in a Panasonic NN-A720M MICROWAVE / CONVECTION oven
Remove the outer cabinet but beware that doing so will expose you to dangerous, even lethal, voltage even with power disconnected. Find and remove the lamp and install replacement. Reinstall cabinet.
Dec 03, 2016 | Panasonic Microwave Ovens
My panasonic NN-8500 microwave/convection oven the microwave part is working fine but,the convection grill defrost is not
Possibly the defrost heater element has failed. You will need to strip the cabinet off and use a multimeter to test the element. May also be the overtemp safety thermostat may have failed.
Nov 19, 2016 | Panasonic Microwave Ovens
Burning smell motor not working
Unplug the oven and unfasten the cabinet body, using a screwdriver. The body should be attached along the back as well as along the sides or bottom.
Slide the cabinet body back slightly to clear any internal brackets, then lift it off.
Clean the oven, using a vacuum with plastic crevice attachment. Vacuum the fan and other internal parts, then vacuum the vents underneath the oven, on the back and inside the chamber.
Reassemble the oven and plug it in.
Fill a small bowl with a 50-50 mixture of water and white vinegar, then set it in the oven and turn the oven on high for 5 minutes. When the mixture boils, it will remove stubborn smells inside the vents and loosen food particles on the oven walls.
Oct 05, 2011 | Panasonic NN-S963BF Microwave Oven
Panasonic microwave ovens touch pad is not functioning in winters. But works well on a warm day. Do I need to clean out something specific?
That sounds like a condensation problem as when the microwave is cold the warm air from the kitchen that is laden with moisture is condensing and upsetting the control panel.
Keep it warm and dry? There is nothing specific though.
Feb 02, 2011 | Panasonic NN-T993SF Microwave Oven
Light out inside
You will likely have to remove the cabinet to access the light to replace it.
I take it yo have already looked inside and found no access ...
6 or 8 screws on the back and probably 4 - 2 on each side should do the trick.
Warning ... dangerous voltages inside the cabinet.
Jun 26, 2010 | Panasonic NN-C994S Convection/Microwave...
Just quick working no warning. no power.
Remove the cover and check the fuse that should be on the floor near where the power cord enters the cabinet.
Thanks for your interest n FixYa.com
Jan 27, 2010 | Panasonic NN-S543BFW Microwave Oven
The door won't latch closed and the door release button pushes all the way in
I have the NN-T994 SFR model and it had a switch that was staying depressed. I removed the screws to (in my case) the stainless steel cabinet, removed the cabinet and unhooked the wires to lay it aside. Found that the switch was cracked or broken, glued it back exactly as it was, then put the cabinet back on and it fixed it! Now about a year later, I have another problem...oh well. Hope this works on yours.
Sep 28, 2009 | Panasonic NN-T990SA Microwave Oven
Whilst cooking strong smell of plasic & cabinet became too hot to
May be a shorted metal stirrer fan bearing located within the wave guide that feeds microwaves into the cooking area. If the oven is run without a proper load (water, or food), the voltage of the microwaves increase considerably causing things to arc-over inside the wave guide. You usually can't see the stirrer bearing short as it occurs internally.
Jul 23, 2009 | Panasonic NN-H765 Microwave Oven
NEED HELP WITH MICROWAVE
door not making connection??? remove the cabinet, and check all switches at least 3 switches in there that need to be making contact, any one being bad, will prevent unit from heating. check also the switch holder(s), that might be broken preventing proper connection
Mar 04, 2008 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
12 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
