Question about Intel Desktop Board D845EPI Motherboard
Trying to wire up the motherboard switch connection
Everything is wired up, except this. I don't have a manual. I want to get this up and running corrcetly.
  • Jim Thurston May 11, 2010
    How far along are you?? What is the model number??
    Problem Solver:
  • 5 Answers
If you need the header connections, they are printed on the MB about 2 inches above the header
Posted on Jul 12, 2009
    Scholar:
  • 113 Answers
Peg perego gator model IGOD004
those are the wires that connect into the battery
Jul 01, 2013 | Toys
I want all the pin details of motherboard diagram for GA- 8i845GV
Download the manual from Gigabyte;
http://download.gigabyte.eu/FileList/Manual/motherboard_manual_8i845gv_e.pdf
In order to view the manual you'll also need to download and install Adobe reader; http://www.adobe.com/products/reader/
With Adobe you can zoom in on any page. The manual is put together in such a way that you'll be able to connect everything. Most people have trouble connecting the, chassis front panel. Since wire colors vary from case to case you'll find each two pin jumper will share a specific wire color. Normally this common wire color is white and is used as negative.
(Except for the MB speaker). Common wire color for the speaker is, "red for positive and black for negative".
Take you're time and follow the manual.
Mike
Apr 28, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Get no power with intel d875pbz in rosewill tu155 case
You don't have the power switch connected where it belongs. There's one set of pins where all the front panel connections go. This information is from the manual for this board, available from Intel here.
Hope it helps. Thanks for using Fixya!
Feb 12, 2010 | Intel D875PBZ Motherboard
I'm trying to wire a 12v bilge manual pump to a
You run your hot wire to the switch (brown) and black wire to the pump (+ve connection). Then from the pump run another wire to the negative terminal of your battery. I used to use a toggle switch on mine, but I do not use a starter motor, still all the lights, radio and echo sounder are connected to it (via a junction box). The only item I fuse is my echo sounder.
Feb 03, 2010 | Boating
I need the front panel pin layout for a Gigabyte 8S648FX-RZ motherboard. (that is the power switch, reset switch, LED etc.)
Open the link for your Gigabyte MB 8S648FX-l;
http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s648fx_rz(c)_c.pdf
This is your manual. Go to page 15. You can enlarge the image if needed.
You will need Adobe Reader to view the manual. If you need Adobe it is a free download;
To view the main link for the Gigabyte 8S648FX-RZ click below;
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1775
Case front panel wire colors can be confusing. Most cases use colored wires as their +positive. White is commonly used as the -ground wire. Except when connecting an internal speaker. Black colored wire is ground.
Cheers!
Mike
Oct 13, 2009 | Gigabyte GA-8S648FX-L Motherboard
Need help wiring Intel Desktop Board D915PGN motherboard
Here you go. Address this manual for your system board from Intel's site, checking and double checking your connections.
http://download.intel.com/support/motherboards/desktop/sb/c6413602_en.pdf
Most commonly it is a disconnected CPU Fan or Chassis fan.
Let us know if you need more assistance, we shall continue to help you troubleshoot.
Apr 17, 2009 | Intel Desktop Board D915PGN - Motherboard...
Pin connections on the motherboard of Acer Aspire AX3200-U3600A
You'll need to know the model of your motherboard, and search for the motherboard manual in the internet if you don't have one.. in the manual search about the power pin connections and you will see where to connect those wires into the pin..TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
Motherboard P4M800CE-8237 Pin connection
Hi ohfs55, case's vary & so do the wire colors. The most common wire color for positive are colored wires. Blue, Green, & red. The most common color for negative is White & or black. I wasn't able to find your manual. If you have the manual for the motherboard there will be a page that will show where the positive & negative wire's connect for each jumper to the motherboard.
Without the manual I can not guide you through each connection. PW = power switch, RW =Reset switch, HD_LED = Hard drive LED ECT.
Mike
Oct 21, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Hooking my Neo4 mobo back up.
Hi weeman105, case wire colors do vary from case to case. The most common case wire colors for negative are "white & black". All other colors like blue, green, red orange are most commonly "positive". The four pin connector with only the ends with wires is the internal speaker. Most boards use one set of pins where you hook everything up. The MSI K8N Neo4-F uses two separate motherboard pins, Front Panel Connectors: JFP1 & JFP2 as shown on the top page 2-19. Now that you know what color is positive & which is negative things should work out just fine.
Downloaded manual from MSI link: http://global.msi.com.tw/index.php?func=downloadfile&dno=4117&type=manual
If you run into any other troubles, just post & we'll go from there.
Good luck weeman105!
Mike
Sep 13, 2008 | MSI K8N Neo4-F Motherboard
Power button wiring help
Hello Chub, Your motherboard manual can be downloaded at this link: http://support.asus.com/download/download.aspx?SLanguage=en-us If you go to page 2-31 in the above manual the diagram should show you exactly where your front panel power switch connects to your motherboard. You want to connect it to the position marked below as ?ATX Power Switch?. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 15, 2007 | ASUS A8V Deluxe Motherboard
Intel Desktop Board D845EPI Motherboard Logo
124 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
